some from head: y8/y7
Old Mar 16, 2006 | 04:46 PM
minime_EK's Avatar
Default some from head: y8/y7
sup honda tech, got a problem, I did this mini me swap about a month ago, and been fixing the little problems here and there, i'm just about done. Heres the problem, the head after it starts up, has smoke coming from it. Did a compression test got 210 on all cylinders, also smoke comes from the tail pipe its not white or smells sweet. Could this be a running rich problem?
mods:
redone y8 head: new valve seals, resurfaced, valve adjusment
y7 block with 145xxx miles
y8 auto manifold
y8 fuel injectors
y7 ecu
Old Mar 16, 2006 | 05:42 PM
Slothy's Avatar
Default Re: some from head: y8/y7 (minime_EK)
Is it black at all? Mine runs rich, but im using a p2p ecu (stock 00 ex ecu) and have a bad 2nd o2. Your since you are using a y7 would be a p2e. Do you have any CEL? The non-vtec ecu would probally mess up things as well.
G Jones
Nov 17, 2023 12:16 AM
Ekevans08
Dec 12, 2012 06:11 AM
EJ8 944
10
Jan 27, 2007 03:51 PM
SOHC_MShue
Oct 13, 2003 07:28 PM
