Wheel Horsepower?
Old Mar 16, 2006 | 04:32 PM
CodyC142's Avatar
Default Wheel Horsepower?
I plan on buying an EG.. doing a GS-R swap.. then turbo, then internals, and more psi,.. anyyways, does anyone have a eg with a GS-R turbo, running like lower than 10 psi? if so whats your whp
Thanks
-Cody
Old Mar 16, 2006 | 04:53 PM
Relic1's Avatar
seriously depends on the tuning involved.
stock GSR with 8psi and a decent tune should pull ~250 whp.
Old Mar 16, 2006 | 04:56 PM
murmur9's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">seriously depends on the tuning involved.
stock GSR with 8psi and a decent tune should pull ~250 whp.</TD></TR></TABLE>
agree
Old Mar 16, 2006 | 05:38 PM
x0!'s Avatar
x0!
Size of turbo and the tuner make it vary.
Old Mar 16, 2006 | 05:45 PM
schardbody's Avatar
i hope you put them in the wrong order.
Old Mar 16, 2006 | 05:50 PM
professor poon's Avatar
Default Re: (JDM=****)
as long as the turbo can put out 8psi, which pretty much all turbo's can, the size only matters for spool-up time, not power...
Old Mar 16, 2006 | 05:53 PM
. a d a m's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM=**** &raquo;</TD></TR><TR><TD CLASS="quote">Size of turbo and the tuner make it vary. </TD></TR></TABLE>
Yeah
For instance, 8psi on a TD05 with a shitty tune is going to have alot less power than a 60-1 with a good tune.
Old Mar 16, 2006 | 05:54 PM
schardbody's Avatar
umm. not true at all poon. you see if you are running 15psi with a 14b its less efficient than running 15psi with a gt28 or so. a smaller turbo running the same boost as a bigger turbo will always produce more heat therefore the air charge wont be as dense reducing power. i know we are talking under 10psi, but your statement is too vague and could confuse people.
Old Mar 16, 2006 | 06:02 PM
dohc-crx's Avatar
Default Re: Wheel Horsepower? (CodyC142)
i have a 300 whp in del sol with stock motor at 7.5- 8 pounds with a full race turbo kit
Old Mar 16, 2006 | 06:05 PM
schardbody's Avatar
300 whp on 8psi???? thats impressive, is that the B16 sol.
Old Mar 16, 2006 | 07:09 PM
b20eg6hatch's Avatar
Default Re: (schardbody)
Here is a website that I have found to show some interesting things. Try http://www.importreview.com, then click on dyno charts. It has alot of info on different cars but it will atleast give you an idea. One of the charts on there showed 230whp for a stock 8psi gsr.
Old Mar 16, 2006 | 08:35 PM
Brodie Bruce's Avatar
Default Re: Wheel Horsepower? (dohc-crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohc-crx &raquo;</TD></TR><TR><TD CLASS="quote">i have a 300 whp in del sol with stock motor at 7.5- 8 pounds with a full race turbo kit</TD></TR></TABLE>
I call BS. Any dyno sheets?
Old Mar 16, 2006 | 08:49 PM
crxnj's Avatar
Default Re: Wheel Horsepower? (Brodie Bruce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brodie Bruce &raquo;</TD></TR><TR><TD CLASS="quote">
I call BS. Any dyno sheets?</TD></TR></TABLE>
300whp is possible..the guy could have a built and ported head with some oversized turbo..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CodyC142 &raquo;</TD></TR><TR><TD CLASS="quote">I plan on buying an EG.. doing a GS-R swap.. then turbo, then internals, and more psi,.. anyyways, does anyone have a eg with a GS-R turbo, running like lower than 10 psi? if so whats your whp
Thanks
-Cody</TD></TR></TABLE>
There are so many variables..I suggest looking around at some dyno sheets of setups to get a basic idea..Heres 203 dyno graphs to look at. http://forums.evans-tuning.com...91de8
92b16si
Sep 25, 2007 10:51 AM
Lil Corb
56
Dec 11, 2006 10:27 PM
4175017
Nov 14, 2006 06:22 AM
beaneg6
Aug 15, 2005 05:50 PM
97dc2
Dec 24, 2004 03:41 PM
