What ecu can i use for my motor?
fuel/ignition maps are a little different. and the JDM ECU doesn't have the ability to read a few sensors that the USDM ECU can.
Honestly not a huge difference, other than price.
P30 will plug into a 92-95 civic (OBD1) - there are OBD2 versions though
Pr3 will plug into a 88-91 civic (OBD0)
Ideally you want to pair a JDM engine to a JDM ECU, but if where ever you are requires emissions testing then you may not be able to run a JDM ECU.
Yeah, i guess im still slightly confused. The date stamp on my motor is 93, which means it was made in 94. So if i have a 94 JDM B16A motor what ecu do i need to use? A pr3 or p30?
Mike
Mike
Well, if the motor is going into and EG, get a P30 or something like a chipped p28.
Also, to confuse you further, there is an OBD1 pr3 that came on the 92-93 integra xti which should work also, but rare to find.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeunreal2 »</TD></TR><TR><TD CLASS="quote">Yeah, i guess im still slightly confused. The date stamp on my motor is 93, which means it was made in 94. So if i have a 94 JDM B16A motor what ecu do i need to use? A pr3 or p30?
Mike</TD></TR></TABLE>
stamped 93 means it was made in 93, the car it was sold in was sold as a 94 model year. It came with a P30.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy »</TD></TR><TR><TD CLASS="quote">Well, if the motor is going into and EG, get a P30 or something like a chipped p28.
Also, to confuse you further, there is an OBD1 pr3 that came on the 92-93 integra xti which should work also, but rare to find.</TD></TR></TABLE>
shhhh don't confuse the boy.
lol
there is a OBD2 P30 also. (96-97 DelSol)
Like SVOboy said...
If the chassis you're putting the engine in is a 92-95 civic then you want a P30 or a chipped P28 with the P30 maps in it.
If the chassis you're putting it in is a 88-91 civic then you want a PR3 ECU. Unless you want to convert the car to OBD1... then you want a P30.
If the chassis you're putting the engine in is a 99-00 civic then you want a P2T ECU.
If the chassis you're putting the engine in is a 96-98 civic then you want either a OBD2a to OBD2b harness and run a P2T ECU, OR a OBD2a to OBD1 harness and run a P30.
confused yet?
lolthere is a OBD2 P30 also. (96-97 DelSol)
Like SVOboy said...
confused yet?
