ls/vtec timing belt issue
Old Mar 16, 2006 | 03:10 PM
92lsvtecpwr's Avatar
Default ls/vtec timing belt issue
hey guys i own a 92 hatch with a 94 integra ls block with a 94 del sol si head...i just recently put a ls timing belt on there and it seemed to work just fine for alittle while it would just rev up and down at idle but im not sure what the cause of that is...the only problem is that the belt was alittle loose coming off the exaust cam gear and tight coming off the intake cam gear...and after about 4000 miles it just ripped the teeth right off the belt and jumped timing and wouldnt start...was i even using the right belt?
Old Mar 16, 2006 | 05:01 PM
Default Re: ls/vtec timing belt issue (92lsvtecpwr)
bump....anyone??
Old Mar 16, 2006 | 05:09 PM
pro1342's Avatar
what water pump?
bigtom388
Oct 4, 2011 09:15 AM
stevenDAtegra
Apr 24, 2009 07:17 PM
fastback94
May 17, 2006 09:28 PM
EFOSV
Jun 16, 2004 07:22 PM
DTAYLOR
Aug 22, 2002 07:07 AM
