Hey guys i got interior questions
Well I got a civic hatch and i would like to change some things and im not sure about a couple of things so i want to find out from you.
Well i have a 97 hatch and i have a grey dashboard. I really want a black dash so which civic model and year came with a black dash that will fit in my car. Ohh also would a 95 and up integra dash fit in with no modification or would it be a hard time with putting it in?
If the integra dash does fit do the door panels from a integra fit also cause i have a power window conversion?
Which seats fit in the hatchback without a gap? integra 4 door or 2 door? And do Si seats fit in back?
Thanks alot all the responses will help alot from me buying things that wont fit.
for the rear pockets i would say no because it all different...as for black...i have not seen it before...mainly dark and light grey, as for teg dash into a 96-00 civic it is do-able but alot of wiring for the gauge cluster, i bet if you do a search for cluster...it might help you decide if you want to do it or not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm_Newb_NYC »</TD></TR><TR><TD CLASS="quote">Well I got a civic hatch and i would like to change some things and im not sure about a couple of things so i want to find out from you.
only black dash is the Civic Type R.. but it's also RHD... there are only two colors for 96-00 model coupes and hatches.. Type F and Type K.. one is light grey one is dark grey..
There usually is gap between the door... and the dash
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy »</TD></TR><TR><TD CLASS="quote">
Well I gotta ? too.
Will the rear side panels like the ones in ex coupes with pockets fit in a ek hatch?</TD></TR></TABLE>
Nope, They are different...
Well I gotta ? too.
You can dye all the interior pieces black. Thats what I am doing now. As for the seats, The integra fronts are almost perfect, (switch rails) the rears are a bit of a bitch. Your civic has a 50/50 split and the integra has a 60/40 split. All I did to get them to fit, was I cut off the mounting bracket, moved it over, and rewelded it in place. Also I had to drill and tap new hole locations for the lower part of the seats to fit.
I thank everyone for their responce. So you guys are saying that an integra dash fits perfect into a 96-00 hatch but the only thing is the wiring for the cluster???
Not too sure about that. Theres a write up somewhere in this forum on the entire dash job. (Itr dash in an ek.) Great write up. He also did a swap, front end conversion, and door panels. Plus a few other things.
