shift linkage needed?
Old Mar 16, 2006 | 12:43 PM
jdmEF8racer's Avatar
Default shift linkage needed?
when swapin my b16 in my 90 HF...do i need a b16 shift linkage or can i still use tha stock
Old Mar 16, 2006 | 12:44 PM
si0385.'s Avatar
Default Re: shift linkage needed? (jdmEF8racer)
your stock linkage will not work
hasport makes a linkage for a b-series swap in a crx
Old Mar 16, 2006 | 12:51 PM
drachir's Avatar
Or you can find a DA shift linkage at the wreckers and shorten it.
Old Mar 29, 2006 | 09:25 AM
aXhatch's Avatar
Default Re: shift linkage needed? (si0385.)
Well Im getting a front clip from an EF9 (SiR) for a real good price. will the shift linkage from my front clip work? or will it also need shortening?
Old Mar 29, 2006 | 09:30 AM
jlicrx's Avatar
Default Re: shift linkage needed? (aXhatch)
if you are using Hasport mounts, you need the Hasport shift linkage - their mounts position the engine a little different than it is in the EF car, so the stock JDM shift linkage doesn't work
Old Mar 29, 2006 | 09:35 AM
aXhatch's Avatar
Default Re: shift linkage needed? (jlicrx)
ok well im getting the avid mounts, will i be able to use the stock EF9 linkage?
Old Mar 29, 2006 | 10:11 AM
jlicrx's Avatar
you need to ask Avid that question
Old Mar 30, 2006 | 04:45 PM
aXhatch's Avatar
ya i got in touch with avid. they helped me out, stock linkage from EF9 works perfect-o
score
now to buy a rywire kit wiht money i saved. My wiring jobs are usually a bit messy
zccr-xsi
Aug 28, 2010 05:58 PM
crxjarred
Sep 30, 2008 06:55 AM
Its me DUB
Mar 2, 2007 08:42 AM
CRX_GUY_123
14
Apr 5, 2004 09:13 AM
