D16Y7 into '89Dx HB
Old Mar 16, 2006 | 11:19 AM
BanginNmy4door's Avatar
Default D16Y7 into '89Dx HB
Ok, I tried to run a search but found nothing. I was curious, how hard is this swap? I know that I will have to convert to multi point, but will I also have to wire it for OBDII? Im really Interested in this swap, mostly because I can get the motor for cheap, and my D15 is about to crap out on me. Any info or links would be greatly appreciated. Thnx
Old Mar 16, 2006 | 11:51 AM
Nobody has any thing to say to this?
Old Mar 16, 2006 | 03:16 PM
JUN.'s Avatar
Default Re: (BanginNmy4door)
use crx si intake manifold, wiring hardnes including resistor box and injectors, and pcm
Old Mar 16, 2006 | 03:24 PM
green91's Avatar
Keep your obd0, use a mpfi manifold and a pm6. You will also need to use the stock driver side motor mount from your car's original motor, and the timing belt cover will require modification. You could also use a d16y8 intake manifold, it flows much better than a Si mani does.
Old Jul 24, 2006 | 02:48 PM
Charlie Moua's Avatar
Default Re: (green91)
so the only mount & would need to be changed out would be the D16y7 timing belt side mount (the one that BOLTS into the side of block) ?
on the driver side do i use the y7 or a6 or b7 circular mount bracket?
Old Jul 24, 2006 | 03:38 PM
user 98292739's Avatar
use all your old mounts basicly. Since teh Y7 was hydro you use your cable tranny with all 3 mounts then use your OEM mount thats on your block right now the "a6" one and put it on the y7 block.
as stated the timing belt cover just needs a lil trimming.
Hellzone-1000
Aug 19, 2015 09:04 PM
greenfamily5
16
Jul 12, 2012 11:58 PM
stormmage88
10
Oct 25, 2011 08:26 AM
JDM JEFFREY
May 11, 2010 12:04 AM
metroya_perform
23
Feb 8, 2008 04:58 PM
