Edelbrock intake w/ extra injectors??
Old Mar 16, 2006 | 11:08 AM
tgreaves's Avatar
Default Edelbrock intake w/ extra injectors??
Cant find this anywhere.. What are the steps needed to modify an Edelbrock intake manifold for using 4 extra injectors underneath.. I know that its already setup for this to be done but I cant find the instruction for drilling and tapping the manifold for the injectors and fuel rail..
Basically I just want to mess around with multi injector controls on the AEM EMS system.. Anyone..
Old Mar 16, 2006 | 03:40 PM
Wes V's Avatar
Default Re: Edelbrock intake w/ extra injectors?? (tgreaves)
Contact Edelbrock and ask them about sending the manifold back to be converted.
They do this for the "carb legal" turbo kits. The stock ECU works the original injectors and the supplemental fuel controller works the second set. It's due to modifying the "stock" ECU isn't legal.
Wes
Old Mar 22, 2006 | 11:06 PM
midnitesol's Avatar
the system is setup so that you just tap the holes to the size needed for the extra fuel injectors. just make sure you have the right tap and start drilling.
blakacintegra
May 22, 2007 09:18 PM
S13 slide
Dec 23, 2005 09:19 PM
SUB-0 H23
Oct 20, 2003 09:58 PM
xtal
Sep 17, 2003 03:46 PM
JeremyL
Feb 26, 2003 05:24 AM
