how can i fix my tail light?
Old Mar 16, 2006 | 08:06 AM
slickyo's Avatar
Default how can i fix my tail light?
hey i was wondering how can i fix my tail light because when i turn on my lights the back light dont turn on only the break light works. i try changeing the bulb but it is not working anyonegot any tip? =]
Old Mar 16, 2006 | 09:45 AM
Rikter's Avatar
get an electrical engineering degree and then look to the wires for the problem. If it's not the bulb... its the wires or a fuse or something dealing with electricity. Relay maybe?
I hope you get shocked.
-Rik
Old Mar 16, 2006 | 09:48 AM
rgaray's Avatar
Check the fuses under the dash.
Old Mar 16, 2006 | 10:44 AM
SiR Adam's Avatar
Default Re: how can i fix my tail light? (slickyo)
Aside from checking the fuse, In situations like these, First thing you do is check for continuity , to make sure there is current running through that wire.
Put one lead of a a test light to conductor of the wire, and the other to body(ground) ,
Light not going on means there is short somwhere on that circuti , Perhaps a pinche d wire.
Old Mar 16, 2006 | 11:06 AM
jmv38's Avatar
FUSE.....
immajackuup
May 7, 2010 01:00 PM
ftrms
Dec 2, 2009 11:40 AM
devin_hoang
Nov 22, 2008 02:27 AM
rcosme9272
Honda Civic (2001 - 2005)
Aug 25, 2008 02:22 PM
slowslow
Nov 7, 2005 02:51 AM
