'96-98 B20 into '93 EG???? Help please...
Old Mar 16, 2006 | 08:03 AM
JDM_CivicEG6's Avatar
Default '96-98 B20 into '93 EG???? Help please...
I am planning on buying a '96-98 B20b and swapping it into my 93 Eg hatch I already have a '95 B18B in the car now....it is usually sold as a Long block only...in which it comes with Motor, Intake Manifold, Exhaust Manifold, Injectors, Fuel Rail, Throttle body, Distributor.... no altenator though...(which alt. can be used) I have some knowlegde but would greatly appreciate some help with this swap, (Integra transmission can be used right)...thanks for all the information...plan on going CR/VTEC later...thanks again for all the help would like to hear from a few experienced honda gurus...
Old Mar 16, 2006 | 08:06 AM
Sleepy_Red_hatch's Avatar
Default Re: '96-98 B20 into '93 EG???? Help please... (JDM_CivicEG6)
you must use the transmission and distributor already on the b18 in your car, use the b18 injectors aswell since they are OBD1 compliant. now, from what i have HEARD (no first hand experience) is that the intake manifold sits way too high up on the b20 so you would need to use the intake manifold from the b18. that should be about it.
Old Mar 16, 2006 | 09:11 AM
Default Re: '96-98 B20 into '93 EG???? Help please... (Sleepy_Red_hatch)
So any B Series tranny will work with the B20....can i use the civic mounts or the B20 mounts
Modified by JDM_CivicEG6 at 3:38 PM 3/16/2006
Old Mar 16, 2006 | 09:20 AM
imskatencrzy's Avatar
yes
95EG2
Jan 30, 2010 04:22 AM
jdmb20boi
Jun 24, 2008 03:34 PM
white4doorsi
Feb 28, 2007 08:23 AM
briangeorge91
Acura TL, RL & ZDX
May 19, 2004 07:48 AM
