Help!!where can i find a type r or GSR rear lower arm? the one on my car is a wrong one
Old Apr 1, 2002 | 05:05 PM
chi@1001's Avatar
New User
Default Help!!where can i find a type r or GSR rear lower arm? the one on my car is a wrong one
hi there,
i just had my gsr lowered yesterday, and i found that the rear right lower control arm is not the right one.
It is just NOT a GSR lower arm. It doesn't have the screw hole to have the rear
anti-sway bar attached. so the anti-sway bar is hanging down there.
obviously, i am not the first owner of this gsr.
anyway,just like to know where i can find a right rear lower arm asap.
does a type r arm fit? anyway, i just need one.
if anyone has an idea or you have one, pls let me know.
thx a lot
Old Apr 1, 2002 | 05:13 PM
BROOD's Avatar
Default Re: Help!!where can i find a type r or GSR rear lower arm? the one on my car is a wrong one (chi@100
Don't order the ITR lca unless you plan on changing the other lca and your rear struts to ITR parts. I'd stick to the GSR lca if I was in your position.
I've ordered new GSR lca's from http://www.ahmotor.com as well as some other places. About $60 each.
If your wanting a used lca from the junkyard, a GSR, DelSol Vtec, or 5th gen Civic EX sedan lca will work.
Old Apr 1, 2002 | 05:50 PM
chi@1001's Avatar
New User
should i get the lower control arm?
or the Lower Control Arm Assy?
what's the differnce?
thx
Old Apr 1, 2002 | 08:09 PM
SlipAngleX's Avatar
Is this also considered the Lower Trailing Arm? Where the wheels spindle connects?
Old Apr 2, 2002 | 05:55 AM
BROOD's Avatar
Rear trailing arms run along the length of the car and directly connect to the hub and brake assemblies. Rear lower control arms (lca's) run along the width of the car and connect the trailing arms to the rear frame crossmember.
You want to get the lca's instead of the trailing arms.
Chi@1001: I'm guessing that by asking if you should buy the lca or lca assembly; the lca assemblies probably come with the bushings. The lca's probably just the lca minus bushings. Buy it with the bushings unless you want the upgrade your car with poly bushings.
[Modified by SLPR, 6:56 AM 4/2/2002]
D15B Civic
Suspension & Brakes
11
Apr 30, 2010 10:47 AM
RabbittZ
Suspension & Brakes
10
Jul 5, 2005 11:32 AM
kcjohnnyboy
Oct 1, 2003 06:53 AM
sleepy
Jun 15, 2002 10:20 AM
