Running Lean Or Rich
Old Mar 16, 2006 | 06:10 AM
gary05's Avatar
Default Running Lean Or Rich
How would someone know it there car is running lean or rich? is there any easy way of telling if the car is running too lean or too rich..thanx
Old Mar 16, 2006 | 06:48 AM
SiYouLater's Avatar
Default Re: Running Lean Or Rich (gary05)
Get an air/fuel guage. There are a lot of ways to check. You can check your plugs for a start.
Old Mar 16, 2006 | 08:03 AM
gary05's Avatar
wat color will the plugs be if its runing to rich or lean? thank you
Old Mar 16, 2006 | 09:45 AM
Relic1's Avatar
white = lean
black/wet = rich
(most honda's idle lean though)
smell the exhaust if it smells a lot like fuel you're rich.
Old Mar 16, 2006 | 10:26 AM
killerformula's Avatar
plug electrodes should look like coffee with cream. The base ring should have a thin layer of carbon all the way around, with no buildup anywhere on the unit.
K
Old Mar 16, 2006 | 10:58 AM
sirshan's Avatar
Rich = smells like mad fuel, gas runs out quick...car doesnt feel like its moving when you do a full throttle...etc. Couple things...Im no pro, but my car is currently runing too damn rich and in the middle of tuning it right now.
Old Mar 16, 2006 | 10:59 AM
SiYouLater's Avatar
Default Re: (killerformula)
I have a queston, I just put in new plugs like a week ago and there is already carbon buildup on the second day of running them. Is that normal? This is on a d16z6.
Old Mar 16, 2006 | 11:03 AM
sirshan's Avatar
Carbon build up should be fine...if you see fuel in there, then thats a no no.
sooo_slow
Mar 7, 2005 07:07 AM
H22CL
Jun 20, 2004 11:11 AM
jeremy.
Sep 27, 2003 02:12 PM
Loveless
Apr 2, 2003 03:17 PM
B00ST2nR
Oct 19, 2002 02:36 PM
