squeking clutch pedal.. need help
Old Mar 15, 2006 | 11:21 PM
redDAinteg's Avatar
Default squeking clutch pedal.. need help
my clutch pedal is squeking everytime I let off of it. How can I fix this?
Old Mar 16, 2006 | 12:09 AM
Spectrum24x's Avatar
Default Re: squeking clutch pedal.. need help (redDAinteg)
let me know if you find a solution. i got the same problem
Old Mar 16, 2006 | 12:33 AM
zeroz's Avatar
Default Re: squeking clutch pedal.. need help (Spectrum24x)
lube it?
Old Mar 16, 2006 | 03:50 AM
integra3586's Avatar
Default Re: squeking clutch pedal.. need help (zeroz)
probably needs lube on the pivot point on the clutch fork. you have to pull the tranny to get to it so i would either make an excuse to put a new clutch in there or live with the squeak
Old Mar 16, 2006 | 08:02 AM
RaceMyGhost's Avatar
Default Re: squeking clutch pedal.. need help (B18B-SC)
it could be that the rubber piece on the pedal, the thing you put your foot on to push the pedal down. i know my car clutchs rubber thing was loose, so everytime i pushed and let off the clutch, it would make a squeeky noise. try to secure it someway or replace it if its old and beat up.
Old Mar 16, 2006 | 09:56 AM
sooo_slow's Avatar
New User
Default Re: squeking clutch pedal.. need help (RaceMyGhost)
Its the honda squeak, very common amoung older models. I've just gotten used to mine.
Old Mar 16, 2006 | 10:18 AM
redDAinteg's Avatar
Default Re: squeking clutch pedal.. need help (sooo_slow)
i was looking carefully and i think its the spring. what if i were to spray a little silicone spray on it to lubricate it ?
Old Mar 16, 2006 | 11:27 AM
VTteg's Avatar
Mine does that too, but only after 20 or so times of pressing in the pedel. Ive learned to live with it. One remedy that ive heard is to locate the rubber boot around your slave cylinder and pack it with grease. I would imagine that if it doesnt fix the squeek, it might dampen it.
Old Mar 16, 2006 | 01:00 PM
lacking vtec's Avatar
make SURE it's NOT your clutch cable. cuz if it is, it's bound to snap soon. it happened to me before on my DA. the pedal stayed down on the floor and i was stranded on neutral--during traffic. i couldnt even put it in gear. very embarassing...
Old Mar 16, 2006 | 01:02 PM
Default Re: squeking clutch pedal.. need help (RagingAlcoholic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAlcoholic &raquo;</TD></TR><TR><TD CLASS="quote">make SURE it's NOT your clutch cable. cuz if it is, it's bound to snap soon. it happened to me before on my DA. the pedal stayed down on the floor and i was stranded on neutral--during traffic. i couldnt even put it in gear. very embarassing...</TD></TR></TABLE>
thats when you turn your car off, then use your starter to get you goin (yes i know its very hard on the starter)
Old Mar 16, 2006 | 01:42 PM
Dave_B's Avatar
Either the throw out bearing or like mentioned lube the fork.
Old Mar 16, 2006 | 09:24 PM
96lsintegra's Avatar
lube it, that happened to my car
Old Mar 17, 2006 | 11:21 AM
lobuck's Avatar
Default Re: (96lsintegra)
I had the return spring in the tranny break, which cuase the throwout bearing to be on the pressureplate all the time. I don't think thats your problem though, if its cable I know some bike places sell good cable lube.
Anyone have the spring on the clutch pedal pop off 90-93 integra? Mine poped off twice already in the past month. Any soultions?
98savage
May 15, 2007 10:23 AM
SAPPHIREblue6SPEED
Sep 13, 2003 12:25 AM
SebAyatollah
Jul 28, 2003 12:49 PM
Chip398193
Aug 31, 2001 03:54 AM
