Moon cuts on Bseries valve cover
Old Mar 15, 2006 | 09:34 PM
broketuner-Sol_Si's Avatar
Default Moon cuts on Bseries valve cover
Does anybody know where I can get this done in So cal? I bought a regular type r valve cover a while ago and will soon have adjustable cam gears on the motor, so mooncuts would make things a lot easier.
Old Mar 15, 2006 | 10:50 PM
H.'s Avatar
H.
Default Re: Moon cuts on Bseries valve cover (broketuner-egb16a)
why dont you try classifies [IMG][/IMG]
http://hondamarketplace.com/zerothread?id=1555143
Old Mar 15, 2006 | 10:54 PM
Because I don't want a new one. I want to do that to my valve cover.
Old Mar 16, 2006 | 11:29 AM
anybody else??
Old Mar 16, 2006 | 11:48 AM
DEIVIONCRX's Avatar
dremel
Old Mar 16, 2006 | 03:38 PM
Topdawgg's Avatar
Default Re: Moon cuts on Bseries valve cover (DEIVIONCRX)
its not hard... do it yourself
Old Mar 16, 2006 | 04:27 PM
Default Re: Moon cuts on Bseries valve cover (Topdawgg)
Guess I thought it would be harder than just taking a dremel to it. Maybe I'll try it.
Old Mar 16, 2006 | 04:34 PM
tru_pimp's Avatar
what I wanna know is, how do you guys cut it off the vehicle without seeing where to stop or how far to go?
Old Mar 16, 2006 | 08:12 PM
19t EX coupe's Avatar
Default Re: (tru_pimp)
I've never done this, so don't go out and do it based on what I say, but if I were to do this myself, I would first dedicate alot of time cause it will take 3x as long as you think it will take to complete it...
I'd take of the valve cover and upper timing belt cover so you can see the entire cam gear, get some cardboard or paper and cut out a circle as big as however much cam gear you want to show, then lay that on the valve cover in the right spot, and cut away... It's gonna take alot of eye-balling to get the cuts centered around the cam gears just right, so I'd suggest cut less than the size, and set on motor, look at it, then make adjustments if needed
that's just my ghetto way of doing it, I'm sure there's a tool for it or something
blackoutvtec845
May 11, 2010 05:38 PM
firemanG
Jan 11, 2008 12:31 PM
Stewie
Jan 7, 2003 08:23 AM
nerdish
May 1, 2002 06:28 AM
