foglight installation
Old Mar 15, 2006 | 08:10 PM
egcivicb16's Avatar
Default foglight installation..help
im having some trouble with installing my foglights, everything is hooked up, but still the light on the switch doesnt come on, and the foglights dont light up.
Old Mar 15, 2006 | 08:12 PM
biggnutz123's Avatar
Default Re: foglight installation..help (egcivicb16)
ceck yer ground and power make shure you have a really good groundit can be on a bolt with paint has to be bare metal to bare metal.
Old Mar 15, 2006 | 08:24 PM
egcivicb16's Avatar
Default Re: foglight installation..help (biggnutz123)
regrounded, still nothin...
Old Mar 15, 2006 | 08:31 PM
egcivicb16's Avatar
no ideas?
Old Mar 15, 2006 | 08:33 PM
EGwhat!!!'s Avatar
Default Re: (egcivicb16)
where are you getting your power source from?
Old Mar 15, 2006 | 08:34 PM
egcivicb16's Avatar
battery
SiB16A's Avatar
are u sure it's wired up right? wut kit did u get?
Old Mar 15, 2006 | 08:36 PM
EGwhat!!!'s Avatar
have you checked if your actually getting power to the lights or your switch? you might have some wires mixed up.
Old Mar 15, 2006 | 08:38 PM
egcivicb16's Avatar
i bought it at a local racing store, its the OEM kit, but it didnt come with instructions so i went with the factory wiring write up that jdmlyfestyle did
Old Mar 15, 2006 | 08:39 PM
EGwhat!!!'s Avatar
did you check your wires for power yet??
egcivicb16's Avatar
Default Re: (92civichatchgsr)
ill go check now
Old Mar 15, 2006 | 09:09 PM
egcivicb16's Avatar
well ive got power coming off the battery, but when i test for power at the end of the power cord that is supposed to connect to the interior there is no power there
Old Mar 15, 2006 | 09:11 PM
EGwhat!!!'s Avatar
check the wire it might be sliced some where
Old Mar 15, 2006 | 09:16 PM
egcivicb16's Avatar
no sliced wire, maybe something to do with the relay?
Old Mar 15, 2006 | 09:22 PM
egcivicb16's Avatar
any other ideas?
Old Mar 15, 2006 | 09:24 PM
EGwhat!!!'s Avatar
the problem is with that wire
Old Mar 15, 2006 | 09:26 PM
my_slow_civic's Avatar
Is there a fuse inline with the power wire?
egcivicb16's Avatar
ya its weird cuz right off the battery the terminal is getting power, but no power at the end of the power line..
egcivicb16's Avatar
Default Re: (my_slow_civic)
yeah there is
Old Mar 15, 2006 | 09:28 PM
EGwhat!!!'s Avatar
is it a solid wire i mean is there a fuse on that line
Old Mar 15, 2006 | 09:29 PM
EGwhat!!!'s Avatar
then check the fuse
egcivicb16's Avatar
there is a fuse between the battery terminal to the relay.
Old Mar 15, 2006 | 09:33 PM
EGwhat!!!'s Avatar
there has to be a faulty connection somewhere between the fuse and the relay or it could be your relay check if there is power right after the relay then check if there is power after the fuse between the relay that should set you in the right direction as far as where the loss of power is
Old Mar 15, 2006 | 09:46 PM
egcivicb16's Avatar
theres power after the fuse, but no power after the relay
Old Mar 15, 2006 | 09:48 PM
EGwhat!!!'s Avatar
then its your relay
