foglight installation
foglight installation..help
im having some trouble with installing my foglights, everything is hooked up, but still the light on the switch doesnt come on, and the foglights dont light up.
Re: foglight installation..help (egcivicb16)
ceck yer ground and power make shure you have a really good groundit can be on a bolt with paint has to be bare metal to bare metal.
i bought it at a local racing store, its the OEM kit, but it didnt come with instructions so i went with the factory wiring write up that jdmlyfestyle did
well ive got power coming off the battery, but when i test for power at the end of the power cord that is supposed to connect to the interior there is no power there
Re: (egcivicb16)
there has to be a faulty connection somewhere between the fuse and the relay or it could be your relay check if there is power right after the relay then check if there is power after the fuse between the relay that should set you in the right direction as far as where the loss of power is
