Need Wiring Help On a 00 SI
please help a brotha out haha
my brake lights work, and i bought a test light and the under hood fuse box has power, but only 1 spot lights up in the under dash fuse box...and that spots not even supposed to have a fuse (although i was using a cx/dx fuse cover maybe si is suppose to have somthin there). But the rest of the under dash fuse box doesnt light up for nothin. Also the turn signals dont work when using the switch, however the hazard button works and makes the signals light up in the cluster as does normal. Any idea what could be wrong?...or what the main fuse(s) look like. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forshizzleyaheard »</TD></TR><TR><TD CLASS="quote">damn this forum skeets...all these heads, and nobody has a clue
welcome to honda-tech(seach-tech).com lol idsay check ur fuse boxes and possbily ur bulbs are just burnt out?
</TD></TR></TABLE>welcome to honda-tech(seach-tech).com lol idsay check ur fuse boxes and possbily ur bulbs are just burnt out?
Guest
Posts: n/a
does the chek engine light flash, or even turn on when u turn your ignition (second turn of the key in the ignition) on?
-if not, check you ecu fuse (fusebox under the hood, top left fuse)... ..
more than likely, that should be your problem
If none of the lights ever turn on, and your car just cranks... something must be up .... faulty alarm maybe?
no lights turn on when i turn the key to start not even oil or e-brake,battery nothing and 95% of the fuses under dash arent getting any power(when tested with light tester).
Patrick_S
Jun 8, 2006 07:07 AM
civiceg500
Jan 5, 2005 09:19 PM
GSlowR
12
Oct 5, 2002 07:14 PM
