help help how do you remove an axle on a 92 teg
Old Mar 15, 2006 | 07:02 PM
sosleepy's Avatar
Default help help how do you remove an axle on a 92 teg
Old Mar 15, 2006 | 07:36 PM
sosleepy's Avatar
Default Re: help help how do you remove an axle on a 92 teg (sosleepy)
Old Mar 15, 2006 | 07:55 PM
yellowrexsi's Avatar
Jack up car
Take tire off car.
Unbolt the axle nut
Unbolt and pop out ball joint
Unbolt wishbone and take it off lower control arm. (might need to use a jack to compress the spring to get it over the control arm)
Use pry bar to pop out axle from tranny
Slide axle towards wishbone and remove from car
Install
Push axle into tranny and tap on the end with rubber mallet
then follow remove instructions in reverse
Old Mar 16, 2006 | 03:28 AM
sosleepy's Avatar
Default Re: help help how do you remove an axle on a 92 teg (yellowrexsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowrexsi &raquo;</TD></TR><TR><TD CLASS="quote">Jack up car
Take tire off car.
Unbolt the axle nut
Install
thank you
Old Mar 16, 2006 | 03:50 AM
mr.beeks's Avatar
be careful not to damage seal where axle goes into the tranny if its the driver side axle
exsquid
May 3, 2008 10:23 AM
joker4268
Oct 5, 2007 02:35 AM
crx18c1
10
Apr 17, 2007 10:17 PM
EFin' Kyle
Dec 13, 2005 10:29 PM
B2FiNiTY
Nov 14, 2004 11:08 AM
