Tranny Problems! Need HELP ASAP!
Old Mar 15, 2006 | 06:42 PM
edited's Avatar
Default Tranny Problems! Need HELP ASAP!
So here is the story, i threw a b16 into my ek and everything is hooked up right. i went to go test drive it and it wouldnt move. i ran it through all the gears, and they were there. i could put it into gear without the clutch with the car on but i gave it gas and it wouldnt move. i pulled the tranny and took it to the shop, it checked out ok. it also has a brand new clutch. the linkage is fine because i can get it into gear. when i jack up the car the wheels spin but when its on the ground i wont move. what could be the problem? axles? clutch?
Old Mar 15, 2006 | 07:25 PM
hatchi's Avatar
Default Re: Tranny Problems! Need HELP ASAP! (NigThief)
check axles, bleed the clutch
Old Mar 15, 2006 | 08:06 PM
edited's Avatar
bled the clutch a million times, i am going to buy some new 99-00 si axles are those the correct ones to use?
Old Mar 15, 2006 | 08:50 PM
hatchi's Avatar
yes 99-00 si or 94-00 b series
Old Mar 15, 2006 | 10:54 PM
SOHCkiller's Avatar
could the pressure plate not be holding pressure, and the clutch just slipping constently?
Old Mar 16, 2006 | 05:45 PM
edited's Avatar
Default Re: (SOHCkiller)
see thats what i was thinking, but who knows. i think i am going to get a stock replacement clutch from a 00 si, if that doesnt do it, then see about brand new axles. the tranny checked out, so its gotta be one of those. thanks for all the help!
NAturalEk9
Oct 12, 2009 09:11 PM
Wannarace62188
Jun 12, 2006 07:17 AM
dorikingts
11
May 13, 2005 09:37 AM
Universe95gsr
Feb 6, 2004 06:30 AM
locass316
May 13, 2003 08:53 AM
