USDM vs JDM difference??
Old Mar 15, 2006 | 06:06 PM
ekVtecPower's Avatar
Default USDM vs JDM difference??
im wonderin wuts the difference between a usdm and a jdm motor? and which is better.
Old Mar 15, 2006 | 06:07 PM
JDMKid71's Avatar
Default Re: USDM vs JDM difference?? (ekVtecPower)
ok ill be the first... SEARCH!
/ thread before flaming begins
Old Mar 15, 2006 | 06:08 PM
dreww..'s Avatar
http://www.hmotorsonline.com
quick rundown of the specs there
Old Mar 15, 2006 | 06:09 PM
Out of every
man okay one is made in "JAPAN" and the other is made in the "U.S.". there you go now you know the difference
which is better tho?
Old Mar 15, 2006 | 06:10 PM
Out of every
Default Re: USDM vs JDM difference?? (e gee two)
jdm by a hair by the way
Old Mar 15, 2006 | 06:11 PM
Out of every
both are similar with minor changes like compression etc
Old Mar 15, 2006 | 06:14 PM
Royal_C!ty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e gee two &raquo;</TD></TR><TR><TD CLASS="quote">jdm by a hair by the way</TD></TR></TABLE>
x2 ...
Old Mar 15, 2006 | 06:16 PM
professor poon's Avatar
Some are more different than others, depending on which motor you're talking about. For example, the B18C (jdm) is 180hp whereas the B18C1 (usdm) is 170hp. Not true in all cases though.
Old Mar 15, 2006 | 06:29 PM
rhd_ej coupe's Avatar
JDM is more mony but a lot better looking and quality
Old Mar 15, 2006 | 06:36 PM
schardbody's Avatar
there is no answer to which is better. lets talk about Dseries. i got a D16z6 1.6L sohc vtec makes 127 flywheel horsepower, i also got a JDM D15b 1.5L sohc vtec and it makes 130hp. basically the same out of a smaller motor, why???? no emmisions in JAPAN, therefore they can run higher compression from the factory, and have higher octane fuel. on the other hand you have cost. USDM is definately better in this case, so which is better a few HP or a few $k, you decide.
Old Mar 15, 2006 | 06:37 PM
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">there is no answer to which is better. lets talk about Dseries. i got a D16z6 1.6L sohc vtec makes 127 flywheel horsepower, i also got a JDM D15b 1.5L sohc vtec and it makes 130hp. basically the same out of a smaller motor, why???? no emmisions in JAPAN, therefore they can run higher compression from the factory, and have higher octane fuel. on the other hand you have cost. USDM is definately better in this case, so which is better a few HP or a few $k, you decide.</TD></TR></TABLE>
Also, for us CA residents, JDM is a PIA because of smog referee issues...
Old Mar 15, 2006 | 07:17 PM
NerveAgent's Avatar
Aren't JDM use are ment to use higher octane..
Old Mar 15, 2006 | 07:22 PM
Default Re: (NerveAgent)
well since many of them have higher compression than their USDM brothers, yes they should use higher octane
huskmusk
May 9, 2005 11:57 AM
is3oo
Dec 1, 2003 09:09 AM
Patron
Jan 21, 2003 09:16 PM
Jonathan_ED3
Apr 18, 2002 08:44 PM
JKim0901
Dec 22, 2001 11:52 AM
