Clunking sound/feel (front)
Old Mar 15, 2006 | 05:25 PM
obviousBOY's Avatar
Default Clunking sound/feel (front)
Ive been searching and havent really found what im looking for.
Heres the setup
92 Hatch
B18c5 Swap
Brand New Konis front/rear with 450lb springs in the front
Two things happen:
1)Going over bumps at LOW speeds I will hear and feel a clunking in my steering wheel.
2)When going SLOW if I stab my brakes I will hear and feel this clunk (not as intense as if I hit a bump but you can notice it)
About a week ago I checked to make sure every bolt/nut was torqued down to spec (Everything checked out) And I noticed my right front wheel bearing is starting to go.
soooooooooo.
Tonight I tore into and removed both knuckles (getting both bearings replaced) And checked everything in there...and...everything seems to be fine.
What should I be looking for?
Could that bearing becausing the clunk?
Thanks Guys
Old Mar 15, 2006 | 05:29 PM
kaoss_11's Avatar
B A N N E D
clunk like axle clunk or clunk like you forgot to put back bump stops
Old Mar 15, 2006 | 05:33 PM
obviousBOY's Avatar
Default Re: (kaoss_11)
Bump stops are in there saw them today
Would i be feeling axle clunk in the steering wheel or mainly hearing it?
Thew axles seemed fine nothing was torn. Thats I really know to look for.
Old Mar 15, 2006 | 06:06 PM
killercannible's Avatar
Default Re: (obviousBOY)
I got a bad axel and you can definetly feel it in the steering will. It happens because the ball bearings bind up in the cv joint.
Old Mar 16, 2006 | 06:25 AM
obviousBOY's Avatar
Default Re: (killercannible)
anyone else?
Old Mar 16, 2006 | 06:50 AM
john666's Avatar
Default Re: Clunking sound/feel (obviousBOY)
when my motor mount screw wasnt tight i kept hearing a thump or whatever sound.. then i looked at it the screw wanted to fall off lol.
xxredpreludesixx
Sep 14, 2005 02:45 AM
sporty240
Aug 22, 2005 10:16 AM
17GSR17
May 22, 2005 07:42 PM
inty2511
Jun 9, 2004 09:56 PM
