Car stalls after Fast acceleration an coming to a stop
soo now today i took my car for a drive to play around with it.. so i Got on it slamed into 2nd spun for a bit then hit 3rd then i slowed down fast so i pushed in the clutch without downshifting came to a stop n it just Stalled on me...like i didnt even feel it cut out.........THEN i tried to start it n it came on but as soon as i hit the gas it seemed to cut off once more...then i started it again n it just seem to run okay...
this always happens when i get on the gas hard.. Any suggestions?
Check the timing, my buddy had the same prob in his 94 coupe. Also, do you check the emissions, any leak there can do this to ya too. And, as previously suggested, the idle screw
most def a vaccum issue but could possibly be a sensor i would recomendchecking the map sensor (also a good note:do not disconect the map sensor while the car is running)
1. Not low on gas
2. Wheres the map Sensor?
3. Do i need the Vacume lines that go from the Intake manni to the fuel rail(the one on the right of the three that are on the intake manni..i think its the one causing the problem)
o0o also...when i start the car up it seems to idol fine but then when it gets warm after driving it it starts to bog out almost till it cuts off then the rpms go back up to about 1000 then it does it over n over again
New Motor... Idle at 250 RPM's... and stalling at stops... try'd other forums... can you help????? D
warchild69
15
Apr 19, 2008 02:20 PM
