Bearing Size Recommendation
Old Mar 15, 2006 | 04:39 PM
SPOOLINmatt's Avatar
Default Bearing Size Recommendation
on my crank mains im measuring
in order from #1 pistons side over
#1 .038mm #2 .038 #3 .025 #4 .025 #5 .025
ok so i know from this that im going to go a size up on 4 and 5 because i dont like how small those are. #5 actually was beat up, i slid the upper one out from behind the crank and it was beat up too. looked like trash got in there, the actual crank journal looked like it did when i installed it. im running acl race bearings now so they are all green. im going to replace 3 4 and 5. i know 3 needs to have atleast a clearance of .030 so its out of spec to tight. can any of you give a reccomendation on what color to order for these mains im going to replace. im going bigger on all 3. .038 is well within the limits on the loose side.
Old Mar 15, 2006 | 05:21 PM
rainforest's Avatar
Default Re: Bearing Size Recommendation (SPOOLINmatt)
first off each size up or down on bearings is .003mm so if you are at .025 and need to be at .038 you need a thinner bearing by 4 sizes. now it only goes down 3 sizes from green so i would try the thinnest bearing wich is a red. try that and post your results.
Old Mar 15, 2006 | 05:42 PM
Default Re: Bearing Size Recommendation (rainforest)
thanks you helped a lot with telling me how much difference there is in the bearings.
Old Mar 15, 2006 | 06:02 PM
yeah i guess ill pick up 3 sets of red tomorrow, that should get everything clearanced out right. B20 colord bearings are the same measurements as the b18 measurements arent they cause thats what im havint to buy it b20 cause i dont have a local acura dealer.
Old Mar 15, 2006 | 08:49 PM
uhh would measuring with plastigage with the the weight of the crank on the plast side throw off the measurement?? being that the motor is upside down from what it normally would be on an engine stand??
Leimokei
Sep 29, 2006 01:24 PM
waxbunny
Oct 14, 2004 07:51 PM
SHhh__VTEC
Jun 2, 2004 11:19 PM
