rough idle
try searching first bro. this topic has been covered a million times over!
but i will help you out this time these are the things that could cause this
vac leak
bad gasket
cracked manifold
iacv needs to be cleaned
fitv needs to fixed ( there's a thread about this in the faq's)
air trapped inside the coolant lines
chipped ecu could cause this
check the pcv & the tps
there you go! good luck
im not sure if i missed anything so if i did oh well. someone else could add on
but i will help you out this time these are the things that could cause thisvac leak
bad gasket
cracked manifold
apbtwhiskey
Apr 5, 2013 01:51 PM
