91 si hi i need help honda runnnin
Old Mar 15, 2006 | 03:44 PM
orangeracer's Avatar
Default 91 si hi i need help honda runnnin
i have a 91 i rebiult my motor an the engine light comes on after like 5 secs an then engine wants to die give gas it is fine well til u let off have any ideas
Old Mar 15, 2006 | 04:43 PM
crxnj's Avatar
Default Re: 91 si hi i need help honda runnnin (orangeracer)
Are you getting any codes..?
Old Mar 15, 2006 | 04:53 PM
i dont have a comp to use do u think i have to have one of them to tell
Old Mar 15, 2006 | 04:57 PM
crxnj's Avatar
Default Re: (orangeracer)
Yeah you pull back the carpet on the passenger side and you'll see the ecu..There will be a little red light blinking. Look here for how to read the blinks https://honda-tech.com/zerothread?id=468260
Old Mar 15, 2006 | 04:59 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orangeracer &raquo;</TD></TR><TR><TD CLASS="quote">i dont have a comp to use do u think i have to have one of them to tell </TD></TR></TABLE>
Nope! If you can pull the carpet away from the passenger footwell, you'll be able to see your car's ECU underneath a brass-colored plate.
With the car on, you will see a red flashing light that will flash in cycles. For every long light, add 10, and for every short flash add 1. The light will stay off for a period between codes in order for you to know where one code starts, and another one stops. Write down as many of these unique patterns as you get, and let us know.
Rmember though, it will keep repeating the same codes forever, so just write down all of the unique ones.
Old Mar 15, 2006 | 05:02 PM
thanks guys ill let u no tomorow
Old Mar 15, 2006 | 05:12 PM
it blinks 3 times
Old Mar 15, 2006 | 05:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orangeracer &raquo;</TD></TR><TR><TD CLASS="quote">it blinks 3 times </TD></TR></TABLE>
Map Sensor.
If I remember correctly, that would cause hesitation.
Old Mar 15, 2006 | 05:20 PM
yea a lil but i think that this vacum line is suckin an pullin the throtle body shut is it soppose to
Old Mar 17, 2006 | 12:54 PM
is there any place to get a map sensor for it for cheep
dumpling101
Jan 25, 2006 06:47 AM
vvtli78k
Mar 18, 2005 09:09 AM
4dohs4mohoes
16
Nov 9, 2002 03:57 PM
