feul pressure regulator with Hondata?
Old Mar 15, 2006 | 03:27 PM
Slightlyimperfekt's Avatar
Default feul pressure regulator with Hondata?
I recently tuned my ls-vtec using Hondata. I didn't want to run a feul pressure regulator (due to the cops) so my tuner said as long as I run big injectors (440s), I'll be fine. The tuning was succesful! I pushed the power I wanted while being able to pass visual inspections by cops! Now i've been hearing comments that its not good to tune that route because the feul leans out in the upper RPMs. What do you think? Do I have to run a regulator? Keep in mind, it will be Hondata tuned. Thanks for your input.
Old Mar 15, 2006 | 03:42 PM
NJIN BUILDR's Avatar
Default Re: feul pressure regulator with Hondata? (Slightlyimperfekt)
If you don't need to increase the fuel pressure then the stock regulator will be fine.
turbotime
Sep 23, 2005 06:31 PM
TurboTeG4
Dec 15, 2004 01:24 PM
MtnCRX
Aug 20, 2004 09:48 AM
DLB1994
Jan 2, 2003 01:39 PM
skrewdlude
Aug 6, 2002 12:56 PM
