how to install a AEM Fuel Pressure Regulator
Old Mar 15, 2006 | 03:24 PM
sixtodc2's Avatar
Default how to install a AEM Fuel Pressure Regulator
i need help on that .. ??```
Old Mar 15, 2006 | 03:56 PM
Racermech's Avatar
Default Re: how to install a AEM Fuel Pressure Regulator (sixtorice)
https://honda-tech.com/zerothread?id=1230435
Dont forget to check out the FAQ at the top of the main page.
Old Mar 15, 2006 | 04:01 PM
LoseRPunKx182's Avatar
Default Re: how to install a AEM Fuel Pressure Regulator (Racermech)
2 bolts on the rail, take old one off, put new one in, tight bolt.
make sure u have the o-ring still and a fuel pressure gauge
Old Mar 15, 2006 | 04:56 PM
rdblckSV650S's Avatar
Default Re: how to install a AEM Fuel Pressure Regulator (LoseRPunKx182)
My FPR came with instructions.
You need to remove the bolt at the top of your fuel filter. Fuel will spray out as the system depressurizes. Then you can remove the stock FPR, and put the AEM one on. Then hook everything back up, tighten down the bolt for the fuel filter (this is the one on top of the banjo bolt). Then get in the car, and turn it to ACC 5 or 6 times, you should hear the fuel pump priming. This will repressurize the system. Then you can start it.
To adjust it you need a fuel pressure guage, a wrench, and an allen wrench (don't know the sizes). You need to take the vaccuum line off the FPR and pinch it off, this will show you (on the guage) what your fuel pressure is. Adjust from there. A dyno with a wideband would be a good idea for getting this right. But either way, you'll need more than just a FPR to tune with.
IHEARTMYHONDA91
17
Dec 21, 2008 08:31 AM
foxfai
Sep 17, 2008 10:03 AM
xbn83
Dec 3, 2004 07:12 AM
k_bster24
Aug 25, 2004 07:33 PM
Boostless97Lude
Nov 10, 2002 10:21 AM
