ITR + JRSC. Should I lower compression?
I am at the a place to replace the head gasket.
For performance has anyone seen any benefit to lower compression?
I am looking for facts, not theories.
I know that boost likes less compression, but considering how picky the ITR motor is with a JRSC I don't want to do something that would hurt instead or make things better.
Thank you
Thank you
the only benefit in lower compression is a safety benefit.
your gonna loose power at the same boost level with low compression vs. high compression but you will have a safer longer lasting engine since it will not be so "picky" on the tuning and the fuel you run.
i would lower it......10:1 would be a good compression to use for boost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">the only benefit in lower compression is a safety benefit.
You can also make more power on pump gas by lowering the compression.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">10:1 would be a good compression to use for boost.</TD></TR></TABLE>
lol.. i hope your joking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zakar »</TD></TR><TR><TD CLASS="quote">
lol.. i hope your joking</TD></TR></TABLE>
umm........no
umm........no
On a turbo car lowering the compression will make tuning more boost easier. On a SC car your limited , why would you lower the compression when it's only 10.6.
Take a look in this months Honda-tuning, Matt from Hondata shows you a stock type R will make good power. ( With one of our intercoolers,,,
TehMoonRulz
May 16, 2005 01:15 PM
