difference in Golden eagle 84mm gasket and drilling a CR-V gasket??
Old Mar 15, 2006 | 01:24 PM
mrbsponge's Avatar
Default difference in Golden eagle 84mm gasket and drilling a CR-V gasket??
wanted to know what would the difference be between buying a golden eagle 84mm gasket and just drilling a hole in the CRV gasket for vtec oiling??? anything??
Old Mar 15, 2006 | 02:17 PM
DaveF's Avatar
Default Re: difference in Golden eagle 84mm gasket and drilling a CR-V gasket?? (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">wanted to know what would the difference be between buying a golden eagle 84mm gasket and just drilling a hole in the CRV gasket for vtec oiling??? anything??
the crv gasket is "esentially" an ls gasket that is 84mm. so there will be no material to go around the oil hole. you need a vtec gasket for a vtec bottom end.
ALL GE gaskets are vtec gaskets that have all dowl holes enlarged, and the bore size is
what you ask for.
supertace91
Oct 26, 2013 12:56 AM
Golden Eagle
May 24, 2012 11:25 AM
Lightsped
12
May 27, 2009 02:20 PM
o0ohaviko0o
Apr 14, 2008 07:09 AM
actionfigure
Jan 7, 2007 07:06 AM
