Idle boucing...w/ sk2 mani and hondata gasket
Old Mar 15, 2006 | 12:21 PM
JDMkidGSR's Avatar
Default Idle boucing...w/ sk2 mani and hondata gasket
Ok so after the install of my sk2 manifold together with the hondata gasket, my cars idle has been going up and down, from 1000-2500rpm's . This has happend to me before but its was the small spring underneath the tb, it was just to adjust it. Ok so i tried checking the spring again and its NOT it. All the vacumm hoses are connected i even used the "T'' to connect the other hose and sensor. I used all the sensors from the stock manifold. OK and my brother also rerouted teh lines for the coolants. Also if this helps when i have the A/C on the car's idle stops for a while at 1500rpm then bounces back up and down for a while then stops.
Any help would be appreaciated. Thanks HT's
Old Mar 15, 2006 | 12:23 PM
yellowrexsi's Avatar
Default Re: Idle boucing...w/ sk2 mani and hondata gasket (JDMkidGSR)
Sounds like a vacuum leak. make sure everything is tight and double check that all your lines are in the correct spot. Did you clean the head good before you put on the new gasket. If there was some old gasket left it would cause a leak
Old Mar 15, 2006 | 12:25 PM
JDMkidGSR's Avatar
Default Re: Idle boucing...w/ sk2 mani and hondata gasket (yellowrexsi)
I'll have to check that out again. take it to the mechanic so he can do it. Dont have the time. Thats what i was thinking but maybe it can be something else.
Old Mar 15, 2006 | 12:29 PM
You can use carb cleaner and spray it over the intake. If it has a leak the carb cleaner will get sucked up by the leak and the car will stall out.
Old Mar 15, 2006 | 12:43 PM
msbhvn_DC2's Avatar
make sure the TPS is hooked up to the correct inlet on the TB. i installed the sk2 IM in my car, got the two sensors crossed and it did the exact same thing you described. when i'd rev it, the motor sounded so f u c k e d !
Old Mar 15, 2006 | 12:55 PM
dohcMONSTER's Avatar
Default Re: Idle boucing...w/ sk2 mani and hondata gasket (msbhvn_DC2)
you have a vaccumm leak. did you remove ALL of the old IM gasket before putting the new one on?
Old Mar 15, 2006 | 01:20 PM
Aloha04MSM's Avatar
i have this same problem. i don't know what is going on. Sorry to thread jack but i though you would like to know someone else has this problem. I have checked for leaks and there are none. It seems that i keep burning out iacv's. i'll replace one then a few weeks later it'll go bad again and i'll have that idle problem again.
Old Mar 15, 2006 | 01:55 PM
B18ceed's Avatar
my iac valve caused the same problem.
Old Mar 15, 2006 | 05:31 PM
Aloha04MSM's Avatar
but did you ever find out why your iac valve went bad? because i can't find what keeps making mine go bad.
Default Re: (b18cinteg96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cinteg96 &raquo;</TD></TR><TR><TD CLASS="quote">but did you ever find out why your iac valve went bad? because i can't find what keeps making mine go bad.</TD></TR></TABLE>
is it grounded out right? are you sure its your IACV?
Old Mar 15, 2006 | 07:11 PM
Aloha04MSM's Avatar
Default Re: (dohcMONSTER)
pretty sure, because i can bang on the iacv and it will close and idle fine. and when i replace it with a working one it will be fine for a few weeks then stop working.
Old Mar 15, 2006 | 08:26 PM
ToNY2012's Avatar
i am having the same problem with my car... and everything is in working condition and brand new on my intake manafold... one of my boys changed his alternator and that fixed the problem.. if any one figures it out please let me know and ill do the same
singlecammin
Jan 20, 2011 07:20 PM
Mr.DXt
Jan 13, 2010 08:27 AM
si_motor_spt
Nov 14, 2008 03:14 PM
[HrZn]4life
May 19, 2005 09:12 AM
ULTRA911
Mar 4, 2003 10:00 AM
