motor mounts
how hard is it to change them i have a 90 accord LX and it just shakes really bad when i come to a stop and was wondering how hard it is and how much it would cost if i had it done if i have to have it done thanks
You can pick them up relatively cheap at any auto parts store and as far as changing them I've seen my buddy replace them it doesn't seem that hard if you have the tight tools.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda4674 »</TD></TR><TR><TD CLASS="quote">how hard is it to change them i have a 90 accord LX and it just shakes really bad when i come to a stop and was wondering how hard it is and how much it would cost if i had it done if i have to have it done thanks</TD></TR></TABLE>
Here's the illustrations for both the Manual and Automatic transmission mount installations. I'll also supply a link for a discount Honda Dealer here in the states if you need a rear mount for an automatic.
Manual: (#2,5,6 and #15)
http://www.hondaautomotivepart...MOUNT
Automatic: (#2,4,6 and #15)
The only mount which is a dealer item only (I believe) is the rear auto mount (and It's the most difficult to replace.
P
P
When you change the rear mount it's easiest to take off the intake manifold.
thats the hardest part.It takes some time but it's not that bad.
Just remember the rear mount is the most important one.You really can't skip and just change the others.It would be a wast of time.
front is easy, both the sides are easy, the rear is a bitch. I am replacing mine right now with a solid rear mount and its a pain in the *** taking out the mount w/o removing the intake manifold. I should be done tomorrow if everything goes well. I am trying to do it w/o taking off the intake mani by using extensions from up top and crowfeet wrenches from under.
If you can rig something to support the engine (either from to top OR bottom) it will help. It will facilitate removing the bolts so as to be able to remove the intended mounts.
P
P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 »</TD></TR><TR><TD CLASS="quote">When you change the rear mount it's easiest to take off the intake manifold.
Just remember the rear mount is the most important one.You really can't skip and just change the others.It would be a wast of time.</TD></TR></TABLE>
I have replaced quite a few of these and it is much much easier and faster to remove the axle and do it from under the car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Master »</TD></TR><TR><TD CLASS="quote">I have replaced quite a few of these and it is much much easier and faster to remove the axle and do it from under the car</TD></TR></TABLE>
thats good to hear since this is my approach on doing it. i have my engine supported w/ a jack holding up the tranny side and driver side mount is still entact.
was pouring rain all day today so i didnt get to finish but i had the my side (tranny) mount off and decided to solidfy it also while it was out.
thats good to hear since this is my approach on doing it. i have my engine supported w/ a jack holding up the tranny side and driver side mount is still entact. was pouring rain all day today so i didnt get to finish but i had the my side (tranny) mount off and decided to solidfy it also while it was out.
yha i was looking at it today and it seems that the front mount is just like thick rubber and is compleatly crackd on bolth sides and can move back and forword so i know what ill be doing this weekend sucks but good to know whats wrong
BlaccPlasticc
Aug 29, 2013 12:49 AM
Divine Asiatic
May 15, 2012 12:39 PM
dman81
Nov 21, 2010 04:05 AM
