I will paypal $10 to who ever can answer this swap question.
I just did a 00 gsr swap in my 95 cx hatch, i used the obd2 harness and ran the vtec and knock wires and also added the tach wire to the harness. for some reason the alternator isnt charging. i had it tested and its fine. i checked the connector as well as the other wire and they are ok. what else can i check? i also checked the fuses and did a continuity check on the four alt. wires
Did you have the battery checked when they checked the alternator? The alternator can be fine but if the battery is bad it will not charge.
jdm 1080p
Mar 28, 2012 02:11 PM
j spec
Mar 15, 2006 10:38 AM
93civiccxhatch
Aug 24, 2004 07:57 PM
