1st Gen B16 In My 98 Ex Coupe
My friend just gave me his 1st gen b16 out of his CRX which is OBD0 im thinking of putting it in my 98 Ex coupe which is OBD 2 A since my motor is blown. My plan was to change the distributor, alternator, and injectors to OBD1 then use a Step up harness from OBD 1 TO OBD 2 using a chipped p28 ecu. The motor is reliable since it was done over with new rods pistons bearings rings and head valves. Is there anything else i need change to make the OBD 0 motor to OBD 1. Ill be using the conversion harness to go from OBD 1 to OBD 2. Thanks for any help.
5_Lug_B
Jul 3, 2007 06:00 PM
