Just did 00 gsr swap alternator not charging whats wrong?
I just did a 00 gsr swap in my 95 cx hatch, i used the obd2 harness and ran the vtec and knock wires and also added the tach wire to the harness. for some reason the alternator isnt charging. i had it tested and its fine. i checked the connector as well as the other wire and they are ok. what else can i check? i also checked the fuses and did a continuity check on the four alt. wires
j spec
Mar 20, 2006 05:13 PM
j spec
Mar 15, 2006 11:44 AM
not so civic
Apr 3, 2002 10:51 AM
