main relay,why does it work only when i jump it?
Old Mar 15, 2006 | 09:39 AM
crx-king's Avatar
Default main relay,why does it work only when i jump it?
Old Mar 15, 2006 | 12:04 PM
doublethink's Avatar
Default Re: main relay,why does it work only when i jump it? (crx-king)
bad connections inside of it.
either take it apart and resolder the connections, or buy a new one from the dealer.
search comes up with like 50 threads.
Old Mar 16, 2006 | 06:16 AM
crx-king's Avatar
Default Re: main relay,why does it work only when i jump it? (doublethink)
i have like 10 different ones and i tryed them all
Old Mar 16, 2006 | 07:40 AM
crx_88_si's Avatar
how about some more detail on what the car is doing???
Old Mar 16, 2006 | 06:18 PM
crx-king's Avatar
Default Re: (crx_88_si)
when i put the relay in the fuel pump wont work nether will it get spark.but when you jump the wires it works fine,but i want to fix the problem because when you turn the key on,it keeps spraying the injectors...also smells like its running rich...
Old Sep 18, 2007 | 02:09 PM
ClubRX's Avatar
How do you 'jump' a relay will sombody please tell me how?
Thank you
Old Sep 18, 2007 | 04:25 PM
VtecSyndrome's Avatar
Default Re: (crx-king)
Like already posted, get a new relay or repair yours. I say get a new one because you obviously are not capable of properly repairing it.
Old Sep 18, 2007 | 06:08 PM
obd1_crx's Avatar
im not sure its as much the relay as it is the wiring. if you hot wire the relay it works but not off the ignition? to me it sounds like the wires goin to the relay are bad.
Old Sep 18, 2007 | 06:17 PM
HCivExoo's Avatar
Default Re: (obd1_crx)
check your grounds both on your battery and on the thermostat housing if they are bad the relay may just make a loud clicking niose when you try and start it and would explain why you have to jump it off.
Old Sep 18, 2007 | 07:28 PM
ClubRX's Avatar
Default Re: (VtecSyndrome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome &raquo;</TD></TR><TR><TD CLASS="quote">Like already posted, get a new relay or repair yours. I say get a new one because you obviously are not capable of properly repairing it.</TD></TR></TABLE>
Do you know my skills? NO so shut the hell up smartass. I HAVE already resolderd my relay, and tried 3 other relays and guess what, Nothing! So as I have posted earlier I JUST WANT TO KNOW HOW TO JUMP THE RELAY TO THE ECU You obviously are not capable of answering that question, so don't post the same thing sombody already has posted!!!
Old Sep 18, 2007 | 08:03 PM
Default Re: (ClubRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ClubRX &raquo;</TD></TR><TR><TD CLASS="quote">
Do you know my skills? NO so shut the hell up smartass. I HAVE already resolderd my relay, and tried 3 other relays and guess what, Nothing! So as I have posted earlier I JUST WANT TO KNOW HOW TO JUMP THE RELAY TO THE ECU You obviously are not capable of answering that question, so don't post the same thing sombody already has posted!!! </TD></TR></TABLE>
Well i am now assuming your the OP with a different screen name?? Thats useful and doesn't lead to confusion considering you (whoever you are??)never mentioned replacing your relay or resoldering it in the first place it's no wonder your crying over my response, how about being more specific with your questions when posting so you can avoid responses like mine that are based off too many idiots on here not having a lick of sense in the first place. So if you can manage to accomplish this in your future posts then maybe your replies will be more valuable and informative otherwise, it will just be a viscous cycle
Old Sep 19, 2007 | 05:50 AM
ClubRX's Avatar
Well i am now assuming your the OP with a different screen name?? Thats useful and doesn't lead to confusion considering you (whoever you are??)never mentioned replacing your relay or resoldering it in the first place it's no wonder your crying over my response, how about being more specific with your questions when posting so you can avoid responses like mine that are based off too many idiots on here not having a lick of sense in the first place. So if you can manage to accomplish this in your future posts then maybe your replies will be more valuable and informative otherwise, it will just be a viscous cycle </TD></TR></TABLE>
Thank you
How could I be any more specific than that? Wait dont answer that bcuz I dn't give sh*t I just want t know how to jump a relay!! Any1 with intellegence out there?
Old Sep 19, 2007 | 03:27 PM
Thank you
How could I be any more specific than that? Wait dont answer that bcuz I dn't give sh*t I just want t know how to jump a relay!! Any1 with intellegence out there?</TD></TR></TABLE>
...useless
Old Sep 19, 2007 | 03:29 PM
The_Undertaker's Avatar
75.168.105.221
Has to do with the Conventional Flow Theory.
Old Sep 19, 2007 | 03:38 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (1988hondacrxsiR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 &raquo;</TD></TR><TR><TD CLASS="quote">Has to do with the Conventional Flow Theory.</TD></TR></TABLE>
Are you just PWing for the hell of it?
Thank you
Knock it off. Search or start your own thread.
Old Sep 19, 2007 | 03:41 PM
75.168.105.221
Do you know the difference between the Conventional Theory and Theory Flow. You should if you plan to advanced in the Electronics and Electricity Principals.
Old Sep 19, 2007 | 03:42 PM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 &raquo;</TD></TR><TR><TD CLASS="quote">Do you know the difference between the Conventional Theory and Theory Flow. You should if you plan to advanced in the Electronics and Electricity Principals.</TD></TR></TABLE>
Ummmmm...... great? I'm glad you know this and all, but what relevance does it have to the thread?
Old Sep 19, 2007 | 03:49 PM
75.168.105.221
He is explaining why does it work only when i jump it. Duh! Conventional Flow Theory. Electrons trying to find home in a circuit in either series or parallel.
Old Sep 19, 2007 | 03:53 PM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 &raquo;</TD></TR><TR><TD CLASS="quote">He is explaining why does it work only when i jump it. Duh! Conventional Flow Theory. Electrons trying to find home in a circuit in either series or parallel.</TD></TR></TABLE>
Again, that's great that you know your physics.
What help is knowing a physics theory to the OP though? I guess my point is that you shouldn't be posting useless information just to boost your post count.
Old Sep 19, 2007 | 04:03 PM
75.168.105.221
I am not boosting my post count. Proving a point that I am not a NOOB. Posting quality not quantity. This thread needs to be locked.
Old Sep 19, 2007 | 04:18 PM
gator88's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 &raquo;</TD></TR><TR><TD CLASS="quote">I am not boosting my post count. Proving a point that I am not a NOOB. Posting quality not quantity. This thread needs to be locked.</TD></TR></TABLE>
why? why should the thread be locked when it was a valid question looking for a solid answer. By some of your responses, i see you do know usefull info, but answer that Q^
Old Sep 19, 2007 | 05:35 PM
Default Re: (gator88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gator88 &raquo;</TD></TR><TR><TD CLASS="quote">
why? why should the thread be locked when it was a valid question looking for a solid answer. By some of your responses, i see you do know usefull info, but answer that Q^</TD></TR></TABLE>
x2, wtf ever happened to the OP anyway??? this thread is heading downward fast......yay HT!!
88_hatch_ls
May 9, 2011 08:36 AM
toomspeed
May 7, 2009 11:24 AM
JDMdamian95
May 1, 2006 09:45 PM
drew2
Dec 3, 2003 06:48 AM
