Proper procedure for welding thin AL to thick?
Old Mar 15, 2006 | 09:21 AM
Fred Allen Burge's Avatar
Default Proper procedure for welding thin AL to thick?
Hello,
I tried welding some 1/16" AL to some 1/4" last night and coulding get a decent puddle on the 1/4 without burning up the 1/16th. What's the proper technique for this?
thanks!
allen
Old Mar 15, 2006 | 09:27 AM
Motorhead_AZ's Avatar
Default Re: Proper procedure for welding thin AL to thick? (allen22)
Keep most of the heat on the thicker piece. It's hard to maintain a nice puddle by holding the torch in a fixed position (in relation to the seam), so you'd have to move the torch up and down accordingly, but still keep most of the heat on the thicker piece. Add the filler rod along the seam only though.
Old Mar 15, 2006 | 09:52 AM
Default Re: Proper procedure for welding thin AL to thick? (Motorhead_AZ)
Thanks,
So, should I move the heat back and forth across the seam or down the length of it? And, will the puddle actually be on the seam half on the thin and half on the thick piece or will the puddle be mostly on the thick piece?
allen
Old Mar 15, 2006 | 09:59 AM
Imagine that the seam is a horizantal line, you should move the torch along a vertical line to keep the puddle on both pieces. The puddle should be on both pieces evenly. Having said that, you also need to maintain a constant horizantal speed, otherwise you get beads of different sizes and heights (won't be pretty).
Practice makes perfect!
Old Mar 15, 2006 | 10:12 AM
essex's Avatar
pre heat the 1/4
Old Mar 15, 2006 | 11:15 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Motorhead_AZ &raquo;</TD></TR><TR><TD CLASS="quote">Imagine that the seam is a horizantal line, you should move the torch along a vertical line to keep the puddle on both pieces. The puddle should be on both pieces evenly. Having said that, you also need to maintain a constant horizantal speed, otherwise you get beads of different sizes and heights (won't be pretty).
Practice makes perfect! </TD></TR></TABLE>
Thanks, that clears it up!
allen
Old Mar 15, 2006 | 07:43 PM
CRVRX's Avatar
If you pre heat the thicker it will help too.
Old Mar 15, 2006 | 08:44 PM
91TSiGuy's Avatar
Default Re: Proper procedure for welding thin AL to thick? (CRVRX)
What size/amerage tig machine are you using?
Old Mar 16, 2006 | 05:41 AM
Default Re: Proper procedure for welding thin AL to thick? (91TSiGuy)
Miller Syncrowave 180, not sure what amps to set it at to tell you the truth.
allen
Old Mar 16, 2006 | 09:01 PM
91TSiGuy's Avatar
Default Re: Proper procedure for welding thin AL to thick? (Fred Allen Burge)
I'd say go with 3/32" pure tungsten, and set the machine at about 150-160 amps. You may not be using all of it, but it's nice to have it in reserve. Aim the torch straight down onto the 1/4" aluminum until you get a shiney puddle started then slowly tip the torch up to move the puddle closer to the 1/16". Now would also be a good time to add some filler, while dipping at the 1/16" piece instead of the 1/4" to give it some extra thickness.
Old Mar 17, 2006 | 08:48 AM
Bjorn's Avatar
it depends on the joint you're doing - for a lap it should be pretty obvious . For a T, I'd use a tungsten and amps the same if you doing two of the small sections together - 1/16" red and 90-100 amps. My technique on T's is to let the arc ride on the vertical piece, tap the pedal to get a puddle and let gravity drop it onto the horizontal (or with finer control, you "push" the droplet of molten Al, with the arc, down to the base piece). That means you want the thicker section vertical. Having it horizontal means you need big amps to start a puddle, and the thinner vert. piece acts as a heat sink, sucking away heat and melting before you can get the puddle to bridge the seam
Old Mar 17, 2006 | 09:27 AM
Default Re: Proper procedure for welding thin AL to thick? (Bjorn)
Excellent tips guys, thanks, can't wait to try this again!
Fred
DelSolMike
Oct 14, 2013 03:32 AM
blackccoupe
Nov 13, 2010 06:22 AM
cehcivic15
Suspension & Brakes
Jun 11, 2010 09:49 PM
B18EG6
Aug 30, 2006 07:13 PM
elpiar
Jun 20, 2005 08:18 AM
