need help restting my iacv
Old Mar 15, 2006 | 08:08 AM
DC2 Mang's Avatar
Default need help restting my iacv
I have to reset my iacv because it it causeing my car to stall when it it warmed up
how do i go about resetting it?
i was told to turn the car on, let it warm up, hold it a 3k for about 10 seconds then let off, go umplug the iacv then set my idle with the screw and then plug it back in turn my car off and reset my ecu
sound right?
i need to know asap, i have to have my car running properly b tomorrow
Old Mar 15, 2006 | 08:11 AM
Micha's Avatar
FAILWGN
Default Re: need help restting my iacv (JDMdc2lsVtec)
There is nothing to reset. You might need to clean it out.
Old Mar 15, 2006 | 08:20 AM
DC2 Mang's Avatar
Default Re: need help restting my iacv (Blu99teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blu99teg &raquo;</TD></TR><TR><TD CLASS="quote">There is nothing to reset. You might need to clean it out. </TD></TR></TABLE>
are you sure, i had one on there but it wa cracked and my car would idle high then i replaced it and at startup it idles at a perfect 1500, but when its warm it will stall, think i just have to reset my ecu?
or could it be a different problem
Old Mar 15, 2006 | 08:25 AM
Micha's Avatar
FAILWGN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec &raquo;</TD></TR><TR><TD CLASS="quote">
or could it be a different problem</TD></TR></TABLE>
Yeah, try and reset yur ecu then come back. Did you clean out the new one with carb cleaner? Might be all gunked up.
Old Mar 15, 2006 | 08:27 AM
DC2 Mang's Avatar
Yeah, try and reset yur ecu then come back. Did you clean out the new one with carb cleaner? Might be all gunked up. </TD></TR></TABLE>
yea, i blasted the **** ouy of it to same sure its clean, it is one from an obd0 motor and i have and obd1, i just got it from my fiend cuz it fits on the skunk2 manifold and seemed to work right until i got home and the car was warm
Old Mar 15, 2006 | 09:39 AM
IVI's Avatar
IVI
also may want to check the fitv.
are you getting a cel for the iacv?
when you unplug it what happens?
Old Mar 15, 2006 | 05:18 PM
DC2 Mang's Avatar
Default Re: need help restting my iacv (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">also may want to check the fitv.
im not getting a cel, i recently built my motor and with my old iavc it would idle super high when it was cold but when it wamred up it would be fine, with the new iacv it just drops idle when i go to stop the car
slide inside
Apr 24, 2011 11:45 AM
spooned out
Nov 19, 2006 12:24 PM
ap1_s2k
Honda S2000
14
May 9, 2006 11:53 AM
guywitaDA
Dec 29, 2005 11:05 AM
redman223
Jun 26, 2003 08:20 PM
