Things to do while a motor swap?!
Alright guys im finally getting my B18C in my hatch and I was wondering what I should do while the motor is out...
Im going to get a new water pump and timing belt (might as well do it now!!!)
I was looking for a type R fuel pump (any suggestions?)
NGK spark plugs and wire kit
Get a wire tuck done during install
Are there any other recommended things for me to do?
Thanks for your help guys!
After my car is done ill post up some pics
PAT
PAT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunmetalej »</TD></TR><TR><TD CLASS="quote">Its always easier to do a clutch and flywheel while the motor is out.</TD></TR></TABLE>
x2
if your bay is dirty, might as well clean it with the motor out.
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">
if your bay is dirty, might as well clean it with the motor out.</TD></TR></TABLE>
x10000
x10000
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numero sete »</TD></TR><TR><TD CLASS="quote">Alright guys im finally getting my B18C in my hatch and I was wondering what I should do while the motor is out...PAT</TD></TR></TABLE>
Rebuild it
Clean and respray the engine bay
Rebuild it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chong »</TD></TR><TR><TD CLASS="quote">Axles too... mine gave out not too long after.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by q45mm »</TD></TR><TR><TD CLASS="quote">Cam seals</TD></TR></TABLE>
all hoses, vaccume lines, wires, connectors, and obviously engine oil/mtf, tune up parts: plugs, wires, cap rotor, all belts, water pump.. are u trying to keep ps/ac??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.A.R.T B18C1EG6 »</TD></TR><TR><TD CLASS="quote">i say do everything that everyone has said on this thread
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow »</TD></TR><TR><TD CLASS="quote">a new intake manifold, it is way easy to get to while the motor is out of your car so you might as well</TD></TR></TABLE>
new IM? why would he change the IM?
oh u got a b18c1 engine(GSR), yah i dont really like the way that looks, not sure of the performance tho.
My budget will only cover the motor and tranny and full tune up.
unfortunately intake manifold, throttle body and exhaust manifold will have to wait a bit. I just redid my entire brake system, suspension and now motor!
Of all the suggestions I'd say the axels are the most important, unless your axels are in perfect shape that is. Changing them will be a lot of work with your suspension and transmission in, so changing with the engine would be a great route to take.
