weird problem, code 43 fixed!
Old Mar 15, 2006 | 05:38 AM
b18_crx's Avatar
Default weird problem, code 43 fixed!
ive been throwing code 43(fuel system supply) and 17(VSS) for a while. Well i thought it might have been my o2, so i was waiting to complete my obd-1 conversion to fix it. On saturday i replaced the VSS and the spedometer started working again. I drove the car from dallas to houston and no CEl came on. My o2 isn't even hooked up, now my question is shouldn't i be throwing throwing a code for the o2? also how would the VSS(code 17) affect and make the car throw code 43(fuel supply system.)
The only thing that I can think of is that somehow the fuelmaps/timing on stock ecu are affected by the speed that you are traveling.
TYSON where are u to explain?
Old Mar 15, 2006 | 08:30 AM
b18_crx's Avatar
Default Re: weird problem, code 43 fixed! (b18_crx)
anyone?
Old Mar 15, 2006 | 11:01 AM
b18_crx's Avatar
Old Mar 15, 2006 | 11:05 AM
yellowrexsi's Avatar
the 2 are not related. It should be throwing a code for the o2 sensor
Old Mar 15, 2006 | 11:07 AM
kingSfit's Avatar
bump cause i would like to know as well
Old Mar 15, 2006 | 01:04 PM
b18_crx's Avatar
Default Re: (BUN)
someone?
Old Mar 15, 2006 | 08:42 PM
jdeemseerx's Avatar
i would imagine only an electronic speedo would affect fuel maps so that could explain it
Old Mar 15, 2006 | 08:49 PM
b18_crx's Avatar
Default Re: (jdeemseerx)
our speedo's use a cable.....WTF? TYSON where are u?
Old Mar 15, 2006 | 11:03 PM
Tyson's Avatar
Default Re: (b18_crx)
im not an ecu expert, im not sure what made you think i was.
i really dont know whats up. why are you running without an o2 sensor anyway? im surprised the car even runs properly, if at all.
usually if code 17 pops up, its just the contacts in the back of the guage cluster going bad. cleaning the contacts solves that. the electronic VSS is what is back of the speedo and sends a signal back to the ECU. i imagine the speed of the car is tied into the fuel maps that the ecu uses, but i could be wrong. im not the ecu expert.
btw, i was sleeping.
Old Mar 15, 2006 | 11:06 PM
Skidtron89's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18_crx &raquo;</TD></TR><TR><TD CLASS="quote">our speedo's use a cable.....WTF? TYSON where are u?</TD></TR></TABLE>
Yes they are but a wire sends the electronic signal from the gauge cluster where the signal is made to the ECU for the VSS signal pin. Otherwise how would the ECU judge vehicle speed? Stick it's wiring harness out the door and let it flap in the wind?
Old Mar 16, 2006 | 04:35 AM
b18_crx's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">im not an ecu expert, im not sure what made you think i was.
btw, i was sleeping.</TD></TR></TABLE>
thats kool bro......... my car was bogging bad sometimes and then all of a sudden i fix the VSS and boom no codes what so ever.
the reason i havent swapped o2 sensor is because um about to do my obd-0 to obd-1 conversion......hehe
Old Aug 17, 2006 | 02:33 PM
b18_crx's Avatar
damn the code came back!
Old Aug 17, 2006 | 02:50 PM
julio_bOostamante's Avatar
I'm a Jackass
which code? 17 or 43? im getting a code 41 i think.... 4 long bleeps and one short one....thats 41 right?
Old Aug 17, 2006 | 07:16 PM
purple95's Avatar
I have a obd2 gsr swap in my 95 ej, ex model. I have been throwing a code 43 for a while now also. Changed fuel filter, fuel pump, cat, spark plug wires, cap, rotor, coil, and it still is throwing the code. Car feels like it is bogging out at times and it also feels sluggish at times. any suggestions?
crx_si-r
Feb 17, 2010 05:16 PM
EFz6er
Nov 1, 2005 09:39 AM
b18_crx
Oct 27, 2005 05:19 AM
DarkBB4
Aug 27, 2005 09:31 AM
