Gasket Prep??!!??!!
im going to put on my gaskets tonite and was wondering if i need to prep them in any way. like with oil, hondadbond, etc.
they are the valve cover gasket, oil pan gasket and 4 spark plug gaskets.
i have some generic hondabond from a parts store that im gonna use. i know i need this on the valve cover gasket(BTW how muchand where, all around?) but do i need this on the oil gasket? do i prep them with oil?
thanks guys
thanks guys
For the valve cover gasket you put a dab on each of the 4 corners..For the oil pan gasket I dont use any at all and theres been no leaks..Just make sure to tq the bolts within spec..I didnt use any on the o-rings either..No leaks..
Go to hondahookup.com and download the sevice manual for your car,,Its got all the tq numbers and patterns to tighten those bolts..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">For the valve cover gasket you put a dab on each of the 4 corners..For the oil pan gasket I dont use any at all and theres been no leaks..Just make sure to tq the bolts within spec..I didnt use any on the o-rings either..No leaks..
Go to hondahookup.com and download the sevice manual for your car,,Its got all the tq numbers and patterns to tighten those bolts..</TD></TR></TABLE>
on the oil pan you are supposed to put hondbond on the 4 corners where the block meet the plates that have the seal in them, ie,. rear main oil seal plate, and the front plate. (you can see the seam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">Yeah I know,,it says that in the helms..I just dont do it personally on any of the motors Ive ever built and they never leaked..</TD></TR></TABLE>
hey what ever works for you. ive just had some issues with oil leaks, im never gonna skimp on anytthing.
do your self a favor and buy a helms manual, the best money ever spent. you will not regret it.
http://www.helminc.com/helm/pr...KDDD2
you will probably have to change the year
I used some "mr. gasket" I think, I applied it where ever the gasket was going to be. I have also used some blue rtv silicon. Never had a problem with a leak or anything like that. As far as prep work goes, Make sure the surface is really clean. I used a razor blade to scrap off all the old glue, then took some carb cleaner with a rag and scrubbed off all the residue from the glue.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrrugsr »</TD></TR><TR><TD CLASS="quote">cant dl it right now
anyone know the TQ on the oil pan bolts?</TD></TR></TABLE>
9ft lbs there is a special order you need to do them in. and you need to torque them in 3 steps ie,. 3ft ft lbs the first round, then 6 ft lbs, then on the final circle 9 ft lbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrrugsr »</TD></TR><TR><TD CLASS="quote">does that manual you got also show a poc of where to put the hondabond? just trying to get a visual of it.</TD></TR></TABLE>
here ya go, lol i took all these pics when i needed help with my oil pan
^^ what is the red arrow for? It shows the sequence as middle two going across the pan, then right two going across, then left two going across, for the initial 6 bolts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">^^ what is the red arrow for? It shows the sequence as middle two going across the pan, then right two going across, then left two going across, for the initial 6 bolts.</TD></TR></TABLE>
yea if you notice it says to tighten those 6 bolts first finger tight, then to torque the rest clockwise in 3 steps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrrugsr »</TD></TR><TR><TD CLASS="quote">THANKS FOR THE PIC MAN
The tranny is on the left in the pic correct?
Yea i should get the helms huh</TD></TR></TABLE>
yes tranny is on the left
