Best Trans to use SI or an LS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InLimbo87 »</TD></TR><TR><TD CLASS="quote">im still confused, spraying would constitute forced induction meaning your car is not going to be all motor at all.</TD></TR></TABLE>
Yup..All motor means all motor,,Nitrous is forced induction..
What motor do you have ? If you have the ls motor keep the ls tranny,,if you have dohc vtec get the si b16 tranny..
yeah the b16 may be a little too short of gears, your shifts may not fall into your powerband (hence making it slower), maybe you should look into the gsr tranny (especially if this is going to be a daily driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InLimbo87 »</TD></TR><TR><TD CLASS="quote">yeah the b16 may be a little too short of gears, your shifts may not fall into your powerband (hence making it slower), maybe you should look into the gsr tranny (especially if this is going to be a daily driver)</TD></TR></TABLE>
the GSR tranny has good gear ratio's for all motor and forced induction
lol u realize that if u can drive it right, ull be spraying the whole way. Spraying for only a small amount of time isnt going to make you fly by anyone lol. I sprayed off the launch in a 95 ls 4 dr. and ran a 14.3 with only intake, exhaust, and a 75 shot. If i only sprayed in one gear i doubt it would've done much of anything to my e/t.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhoneedsVtec7g’sISplenty »</TD></TR><TR><TD CLASS="quote">tru tru ur right ok all motor then until i have to spray does that make any sense like i'll runn u until im losin then spray
DANGER TO MANIFOLD
careful, your floor board might fall out.
</TD></TR></TABLE>DANGER TO MANIFOLD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec »</TD></TR><TR><TD CLASS="quote">
the GSR tranny has good gear ratio's for all motor and forced induction</TD></TR></TABLE>
true
the GSR tranny has good gear ratio's for all motor and forced induction</TD></TR></TABLE>true
blackb16209
10
Jan 9, 2007 05:45 PM
aLpHa oMeGa
Apr 16, 2006 05:41 PM
