90 Honda Accord problems
Old Mar 15, 2006 | 04:38 AM
hondagurl12006's Avatar
Default 90 Honda Accord problems
Thank you guys for helping me. My car needed new spark plugs but there's still a problem with it. The whole entire car shakes and the engine does,too. Sounds like complete crap.
Modified by hondagurl12006 at 6:34 AM 3/20/2006
Old Mar 15, 2006 | 08:58 AM
Ross 2.0's Avatar
In a Junkyard near you.
As soon as you learn how to spell VTEC...
What is it not getting? Spark, Air/ fuel mixture, low compression??? Do a few searches and you will find how to diagnose the problems individually.
Old Mar 15, 2006 | 11:45 AM
mozzandherb's Avatar
Honda-Tech Titanium Member
Default Re: 90 Honda Accord problems (hondagurl12006)
Could be the fuel injectors.
Old Mar 15, 2006 | 02:32 PM
blueshark's Avatar
Sorry these other guys didn't help you more. Always start off with a spark check. This problem is not usually caused by the dist. cap but more by an ignitor or coil. If GOOD spark is preasent then check fuel pressure. Will need to be over 20 psi. to start cold. If fuel pressure is there then check the ECU for codes. Weather it's VETC or not it needs computer controls.
Old Mar 16, 2006 | 05:38 AM
Default Re: 90 Honda Accord problems (blueshark)
Thank you so much for your help. I'm new at this so I don't know anything. My boyfriend doesn't know much either on Accords..All he knows about is Civics.. Thanks again.
Old Mar 16, 2006 | 07:46 AM
turboH22Aakkord's Avatar
good info blushark...totally right about the comon dizzy problems ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondagurl12006 &raquo;</TD></TR><TR><TD CLASS="quote"> My boyfriend doesn't know much either on Accords..All he knows about is Civics.. Thanks again. </TD></TR></TABLE>
honda's.... are.... honda's they all have plugs,wires,dizzy,injector,fuel pump, ... good luck
and tell your BF to get a real car
Old Mar 16, 2006 | 07:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondagurl12006 &raquo;</TD></TR><TR><TD CLASS="quote">I just recently bought a 90 Honda Accord. It has a newer Honda Prelude V-tech engine in it. I think it's a H22a4 or something like that. When I go to start it it wont start like somethings not getting to something. A few people have suggested its the engine, spark plugs, distributor, or the starter. Will you help me, please.</TD></TR></TABLE>
there really wasnt enough info given to help... will the engine even crank? if so does it even sputter when cranking? a little more info might get you some more help... good luck though..
Old Mar 16, 2006 | 07:54 AM
NAiL05's Avatar
As mentioned if you described in more detail how its not starting we can give you a better diagnosis rather than throwing ideas at you that might not even be the problem.
clownaround21
Feb 18, 2018 03:27 PM
cwarnold77
Apr 5, 2017 01:01 PM
S360turboteg
Dec 13, 2016 02:09 PM
BoostFrenzy.com
Jan 8, 2006 04:24 PM
grendelsmoder
Sep 15, 2005 07:00 PM
