lowering questions
Old Apr 1, 2002 | 01:55 PM
paulyman's Avatar
Default lowering questions
hi guys would like to lower my car this summer
i want to stick to springs.
but i should probably change my shocks while im at it.
i want a tight setup and will be running stock gsr rims and 205/15/15s
but what is a good a shock and spring package for the money that fits the car nice and will not make any problems
thanks for your thoughts
Old Apr 1, 2002 | 03:05 PM
GSRdriver's Avatar
Default Re: lowering questions (paulyman)
KYB/AGX & H&R sports...I love it..
Ran me about 550....installed.
Old Apr 1, 2002 | 03:53 PM
frogsr's Avatar
it's a good idea to change out the shocks to some kind of sport shocks when lowering your car. i've got koni yellow on neuspeed race, and i think they work well together. haven't had a problem at all.
Old Apr 1, 2002 | 04:09 PM
djay86's Avatar
Default Re: lowering questions (frogsr)
Do u need an adapter for the nuespeed springs with koni yellows, cause i know u need one for GC coilovers w/ koni yellows?
How much did this set up run u?
Is it adjustable?
Do u use a camber kit?
thanks!
Old Apr 1, 2002 | 04:14 PM
frogsr's Avatar
Default Re: lowering questions (djay86)
i didn't need any adapter for my springs to work with the koni yellows. i do not know about gc coilovers, so i won't comment on those. the setup ran me $500; i got the springs for free. the koni's have 3 perch settings for the front and rear, ~20mm adjustment. they are also adjustable for dampening. i've had tokico blue (non-adjustable) and didn't like the ride they gave with my race springs. i have a progress camber kit.
Old Apr 1, 2002 | 04:50 PM
djay86's Avatar
Default Re: lowering questions (LSnoVTEC)
If u get tokico blues with the GC coilovers, is your ride adjustable??
Old Apr 1, 2002 | 06:16 PM
Duck Sauce's Avatar
Not the Tokico Blues, but the Tokico Illuminas are adjustable.
Old Apr 1, 2002 | 09:08 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I think Tokico Blues are good for Ground Controls.
Hardly. You need a shock that can handle the reduced ride height and increased spring rate. My friend has Blues and Neuspeed Race and it's pretty bad. You only need an adapter for the Konis when using GC coilovers, not when using springs. GC's are good, but I can only recommend you use them w/ Konis, because of the way they attach to the shock w/ the adapter. It's almost like having an actual threaded body shock.
Old Apr 1, 2002 | 09:31 PM
RC211V's Avatar
Default Re: lowering questions (PatrickGSR94)
NEUSPEED RACE all the way if you planning on rollin on stock rims. good drop and really nice ride that is stiff but comfortable. i would go with the koni yellow bc they are agressivly valved. but i had NEUSPEED RACE on my LS and i loved it. PERFECT!!!
honda_student
Suspension & Brakes
Nov 29, 2007 12:18 PM
redDAinteg
May 10, 2005 12:42 AM
bossman032
Dec 9, 2004 09:56 PM
FBP Ex-T
Feb 19, 2002 05:34 PM
