E-Brake warning light doesn't come on?
my e-brake light doesn't work on my dash. I pull the e-brake up and nothing happens. I checked the fuse and they are all ok and I even tested the switch to see if it was working . The bulb inside the cluster also works but where does the e-brake wire run to? I think there is a positive current that connects to it. Please help I been trying to figure this out for a while.
its negative switched to ground, wire contacts a small metal bracket that touchs the body
check to make sure there are no opens in the wire from the cluster to the switch, get an ohm meter
vthree
May 6, 2006 03:56 PM
