Which pin is the stock VSS cluster pin for 90-91 crx?
Old Mar 14, 2006 | 07:21 PM
C8V6C's Avatar
Default Which pin is the stock VSS cluster pin for 90-91 crx?
I did the cluster swap of the 90-91 cluster into my 88-89.....Everything works perfect, all lights, all turns, all indicators, including tach and speedometer.
The car throws the vss code after a downshift at higher rpm..The speedometer works perfect, so im just presuming its one of the wires left over, since the article doesnt use all the wires
i used the faq/search and found this link:
https://honda-tech.com/zerothread?id=709958
This link was used to match all those crx wires, and i just disreguarded the 00si portion.
If anyone can answer this quick question....which pin is for vss? im still searching as we speak, and havent found the right one.
Thanks in advance
Old Mar 14, 2006 | 08:22 PM
C8V6C's Avatar
Default Re: Which pin is the stock VSS cluster pin for 90-91 crx? (C8V6C)
Anyone have an idea? I think i narrowed it down to the 2-3 wires that were not used....just dont want to cut and solder and guess......dont want to short anything out or get anything too hot
Old Mar 14, 2006 | 11:59 PM
Ak_ef9's Avatar
1990-91 CRX:
12 pin connector:
1) Blue-tach
2)White/Blue-Volts
3)Black/Yellow-12v power
4)green/Orange-Check Engine
5)yellow/Red-Oil Light
6)Green/Red-E brake
7)Green/Red-Door Light
8)Red-Dash-Dash Lights
9)Red/Black-Dash Lights
10)Yellow/Green-Water Temp.
11)red/Blue-High beam
12)Green/Blue-Turn Signal Left
8 Pin connector:
1)Green/Yellow-Right Turn Signal
2)Yellow-12v Power
3)Yellow/white-Feul Gauge
4)Not Used
5)Green/black-Trunk light
6)Not used
7)yellow/red-Speed sensor
8)Black-Ground
if you are looking at the plug from the top and the wires are going ->
Old Mar 15, 2006 | 08:16 AM
C8V6C's Avatar
Default Re: Which pin is the stock VSS cluster pin for 90-91 crx? (Ak_ef9)
I appreciate it very much......thanks for your help for sure!!!
Old Mar 16, 2006 | 12:34 PM
C8V6C's Avatar
Update, that was the correct pin, only I was used to labeling them from left to right, with the clip up
So in fact the 7th pin on the 8pin connector was actually pin 2.
But everything works perfect, i guess when you do the swap, there are two wires not needed, one on both sides of the connectors
Thanks again
french_yogi
Apr 18, 2011 06:24 PM
ef-b16sedan
Jul 7, 2006 01:21 PM
SD_Lurker
44
Jan 7, 2006 05:39 PM
Project_EF
12
Feb 11, 2005 07:19 AM
