homemade intake manifold vs. Edelbrock victor x
well I got arownd to swaping intake manifolds and see what it would do on the dyno. So here are the results.
Both runs at 20 ish psi boost
Red line => my homemade intake manifold with 80mm Q45 tb
Blue line => Edelbrock Victor x with 65mm tb
Very Impressive results. Is that a Ross Machine Racing Plenum half round stock? Did you modify it at all to add a tapper from the throttle end to the last cylinder? Also, what velocity stacks did you end up going with?
Regards,
Justin
Regards,
Justin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Olson »</TD></TR><TR><TD CLASS="quote">Very Impressive results. Is that a Ross Machine Racing Plenum half round stock? Did you modify it at all to add a tapper from the throttle end to the last cylinder? Also, what velocity stacks did you end up going with?
Regards,
Justin</TD></TR></TABLE>
Yes thats the Ross Machine Racing plenum. I did cut it and taper it from the t/b to the last cyl. The velocity stacks I used are from a company in Australia, and the size was 48mm, if I remember right.
Regards,
Maybe I am blind but why are you running soo lean?
Also if you are comparing two different things, the tuning should be equal on both.. not a 1-2 point AFR change between them. IDK if it is just me, but it would be more accurate if they were both tuned to the same point.
But anycase it won't effect it that terribly much. The gains are there, that is what matters.
Im gonna say
http://www.velocity-of-sound.com
Ive ordered from them before and a its a very nice product. The only thing is they use very thin (like 20 guage) aluminum and the stacks are only really good for the inside of the plenum. Not a bad thing but I wouldnt try to support a plenum with them. Perhaps a well braced plenum would allow you to use the stacks as runners as well without worry.
Nice gains there.
Nice gains there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefstek »</TD></TR><TR><TD CLASS="quote">here is one I just took.
Isn't the idea to have a large plenum??? Seems from the pics that you made the plenum pretty small.
</TD></TR></TABLE>Isn't the idea to have a large plenum??? Seems from the pics that you made the plenum pretty small.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefstek »</TD></TR><TR><TD CLASS="quote">here is a pic of the plenum as it was being worked on.
Those are not the same plenum....
I have seen the pic that shows the inside of the plenum before on another build your own intake manifold page.... I call BS. Not hating just don't believe that it is your own....
Modified by tepid1 at 1:26 PM 3/15/2006
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefstek »</TD></TR><TR><TD CLASS="quote">here is a pic of the plenum as it was being worked on.
</TD></TR></TABLE>Those are not the same plenum....
WHy is that? To me it looks like he has modified the original roos plenum to give it the nice taper. ALso you should have sticked your v stack out a bit more, good gains tho
That full race prototype its just like a copy of the greddy supra intake.
.That full race prototype its just like a copy of the greddy supra intake.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Olson »</TD></TR><TR><TD CLASS="quote">Plenum Design reminds me a lot of the full-race s2k prototype unit:
I can say that I never seen that s2k manifold before. nice design,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 »</TD></TR><TR><TD CLASS="quote">
Isn't the idea to have a large plenum??? Seems from the pics that you made the plenum pretty small.</TD></TR></TABLE>
if i do make another one, I will have to make the plenum a bit bigger.
</TD></TR></TABLE>I can say that I never seen that s2k manifold before. nice design,
very nice
