Adjusting Throttle possiton
first disconnect the idle air control valve
second, start the car.
then adjust the idle screw.
the rpm should be around 500-700.
after you have the correct idle.
reset your ecu by pulling the ecu fuse from the engine fuse box.
after that you should be cool.
1baddcivicsi
Mar 13, 2006 08:50 PM
