any way to fix side bumper hole? (pics)
this hole was ripped when i car got hit on the street last year. and it has held up pretty well since then. not comming out. but now for some reason it wont stay in. is there any way i can fix this so my bumper will stay on tight?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlUeDC2nEr »</TD></TR><TR><TD CLASS="quote">just some suggestions...
make new holes
use some fatty washers
good luck with it!
some fatty washers
make new holes
good luck with it!
some fatty washers
make new holes
good luck with it!
Thats what I did. Just made a new hole and used a washer ,bolt and nut.
make new holes
good luck with it!
small piece of metal, make 3 holes, one for your bolt 2 for rivets. rivet it with the flat side of the rivet on the top andthe pieceof metal under the hole. then u will have a fresh solid hole
tools and parts needed:
drill and drill bits
vise
cheap rivet gun
rivets
piece of small metal
all can be found at a local hardware store
good luck
Modified by Mr. HYDE at 8:17 PM 3/14/2006
vise
cheap rivet gun
rivets
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tolowhb »</TD></TR><TR><TD CLASS="quote">Fill that area with Dura-Mix then drill a new hole through that. It is crazy stuff.
yes some sick n' thick ****..
</TD></TR></TABLE>yes some sick n' thick ****..
cut out a piece of metal to fill the gap, use some epoxy to hold it in plac, lay a few layers of fiberglass to bond it to the bumper, then drill new holes. That way the bumper will be less likely to tear in the future at that location, if you secure it right. It shouldnt tear at all.
