Aftermarket Exhaust questions..
Old Mar 14, 2006 | 03:13 PM
Jay.D.Em!'s Avatar
Default Aftermarket Exhaust questions..
When i bought my 89 hatch, it came with no cat...So my exhaust pipe is bolted right up to my exhaust manifold.. Im running a DOHC ZC and i know they use d-series parts so.. im looking for a high flow cat and aftermarket exhaust (Greddy sp2), so..my questions are: do i order the cat for an 88-91? 92-95? or does it not matter? i know i have to order the exhaust for my car (88-91) but it should bolt up to any d-series cat right? just need some clarification..Thanks..
Old Mar 14, 2006 | 03:33 PM
Jay.D.Em!'s Avatar
Default Re: Aftermarket Exhaust questions.. (ILoveMyED6)
bump bump bump cmon you guys 10 views and nobody??
Old Mar 14, 2006 | 03:40 PM
Crx Jimmy's Avatar
I know a 88-91 cat will fit not sure about the 92-95
Old Mar 14, 2006 | 03:46 PM
stockbee's Avatar
stick with the part thati s for you car if Im understanding you correctly.
for the SP it will fit Im sure, as they are stock fitment right?
Old Mar 14, 2006 | 04:11 PM
highflyinhonda's Avatar
Since the ZC came in 88-91 civic and crx's ise the 88-91 d-series parts
Jay.D.Em!'s Avatar
Default Re: (highflyinhonda)
thank you
**use
Old Mar 14, 2006 | 04:22 PM
Mugencrxsir1's Avatar
Well your stuck in a dilema, if your running a stock header, then your stock 88-91 cat should work just fine. The cat for the 88-91 and 92-95 are the same lenght I believe, so either should work. I know most cats for hondas are either 14" 16.75, or 18" for the type-r. So I would say go with the stock 88-91, becuase you buying an exhaust that's ment to fit the your stock cat/header set-up.
Old Mar 14, 2006 | 04:26 PM
Default Re: (Mugencrxsir1)
Or just buy your cat-back exhaust first and do the measurements for the cat. You could also use a univeral cat.
Old Mar 14, 2006 | 04:27 PM
fireant's Avatar
Use a 88-91, and the Magnaflow OEMs CATs are good... they flow better than OEM, and will actually do something for emissions.
Old Mar 15, 2006 | 04:37 AM
Jay.D.Em!'s Avatar
Default Re: Aftermarket Exhaust questions.. (fireant)
thanks...so a high flow cat wont do much for my emissions??? not that i get it inspected anyway.. wink wink**
djrockytharp
Oct 7, 2008 11:55 AM
TheHatchHog
Oct 16, 2004 09:24 PM
