so i found a really good deal on a crx
Old Mar 14, 2006 | 03:06 PM
rob0589's Avatar
Default so i found a really good deal on a crx
my boy needs to get rid of his crx and he was in the middle of doing a ls swap. in the sale he is including the ls motor w/40k miles on it...whgat else do i need besides the motor...will the crx radiator etc. work for that...waht bout the wiring.
Old Mar 14, 2006 | 03:07 PM
dohc_profile's Avatar
wut year is the motor? wut has he done? need more info bud
Old Mar 14, 2006 | 04:19 PM
rob0589's Avatar
not sure of the year...but all he has done so far is pulled the stock crx motor
Old Mar 14, 2006 | 07:30 PM
im not an expert at swapping, im running a d15b2 with a Si head thats all my engine mods so far..but most likely you'll need engine mounts, tranny, ecu, change your wiring to obd1. thats all i can say, hope it helps you out a bit.
Old Mar 14, 2006 | 07:39 PM
doublethink's Avatar
Default Re: so i found a really good deal on a crx (rob0589)
you need to know what model CRX it was. chances are it was a DX with only 2 fuel injectors and he paniced.
if it only has two injectors, its whats know as Dual Port Fuel Injection (DPFI) which will not work with any b-series motor.
first you would have to do a MPFI conversion.
mounts you can get arizona race and machine or HASport or avid or whoever else makes bseries mounts, youll also need shift linkage.
you need to know if its hydrolic or cable tranny. the year of the integra donor car would help. if it was pre-odb or odb-1....... very important
you need to know all of that before you even think of buying that, or else your taking on something youll never finish.
Old Mar 14, 2006 | 08:23 PM
Jesterian's Avatar
24.243.141.75
Default Re: so i found a really good deal on a crx (doublethink)
Buying someone else's project may be a headache.
Old Mar 16, 2006 | 10:43 AM
rob0589's Avatar
he says its a 91 and its dohc
Old Mar 16, 2006 | 11:16 AM
drecivic's Avatar
all integra engines were dohc even the d series zc
Old Mar 16, 2006 | 11:33 AM
92 si hatch's Avatar
I would sell the motor and look for a complete swap. I say this for no other reason than to make the project mine, rather then finnishing someone elses. See if you can find something complete w/ everything but jumper harness if it's needed
Old Mar 16, 2006 | 11:55 AM
FernEF's Avatar
Default Re: so i found a really good deal on a crx (Jesterian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesterian &raquo;</TD></TR><TR><TD CLASS="quote">Buying someone else's project may be a headache.</TD></TR></TABLE>
very true...
Old Mar 16, 2006 | 01:19 PM
rob0589's Avatar
well if he is including the harness...what else do i need?
Old Mar 16, 2006 | 01:24 PM
si0385.'s Avatar
x2...million
Old Mar 16, 2006 | 01:34 PM
.Manny.'s Avatar
Touching My Member
this guy doesnt know ****, go look at the car and ask him more questions, like the ones listed above and then come back. then most of us here will be able to help. we cant read yur mind bro.
Old Mar 16, 2006 | 04:40 PM
rob0589's Avatar
he told me the motor was a 91.... what do i need for it
Old Mar 20, 2006 | 11:52 AM
rob0589's Avatar
so what else do i need if hes giving me the motor and wiring harness...do i need a new computer?
the only reason i am jumping on this deal because the car is mint inside and outside....lambo doors, body kit, 19 inch rims, catback exhaust, brand new paint...
Old Mar 20, 2006 | 01:58 PM
rob0589's Avatar
someone help me
Old Mar 20, 2006 | 02:10 PM
japspecjohn's Avatar
Default Re: (rob0589)
91 what?? DX HF OR Si??????? Sounds like your first time so for your sake to make things easier hopefully its a HF or si
Old Mar 20, 2006 | 04:22 PM
rob0589's Avatar
its an si
Old Mar 21, 2006 | 10:42 AM
rob0589's Avatar
bump
Old Mar 22, 2006 | 10:48 AM
rob0589's Avatar
i need help with this project!
Old Mar 23, 2006 | 05:13 AM
rob0589's Avatar
ok im going to pick it up this weekend...i will post pics
Old Mar 23, 2006 | 05:32 AM
b18_crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rob0589 &raquo;</TD></TR><TR><TD CLASS="quote"> ls motor w/40k miles on it.QUOTE]
[QUOTE=rob0589]he told me the motor was a 91....</TD></TR></TABLE>
i doubt that....... maybe 40k after rebuild
if the crx is an si then wiring is easy........... use your stock harness and it shuould plug right up no problem........ the car is obd-0 or non obd and the motor is obd-0 or non obd
i am running a obd-1 LS in my crx still obd-0. The only problem that i had was the MAP sensor because it was on the TB on my motor. All i did is use a 90-91 integra ls TB and used the crx map sensor. You should be fine. post pics
Old Mar 23, 2006 | 05:55 AM
rob0589's Avatar
ok i will post pics...
yes it has 40k on rebuilt motor....what do i do about headers and downpipe?
Old Mar 23, 2006 | 06:00 AM
rice a roni's Avatar
that sucks...do a mpfi conversion, which sucks...new mounts because the d series mounts dont compensate with the b series mounts...
Old Mar 23, 2006 | 06:02 AM
rob0589's Avatar
ok can someone post me all parts i will need if i have an ls motor, wiring harness and a 1990 crx...also some websites where i can get these parts too...thanks
